Moving CB question
noel_c
Hey guys. Hoping someone can help. I,m relocating my CB but the coax cable from aerial mount is a little short to reach my new location. Can I merely insert additional cable with a connector or do I need to rerun a full new cable?
Thx
Hi Noel
I wouldn't mess with the cable, install new cable,Jaycar do one for about 3o bucks around 5 metres with the connections on..
noel_c
Ok Thanks I,m little confused tho are you suggesting Jarcar supply the cable with connections fitted already? How would I feed this from arial base back into car or are you saying they will fit the cable then the connections?
Chatty
You will either need to replace the cable in its entirety which would be the best option, but will involve soldering the new lead into the antenna base.
You could also get a new cable with an antenna base already terminated on it, which is the equal best option, but a little harder to fit as you have to feed the terminated end of the cable through the vehicle.
You could also get a short length of antenna cable with screw fittings on each end and a female-female joiner which is not the best option, but certainly the easiest.
The staff at Jaycar will be your friends in this - go talk to them.
SPOD_Here
Depends, if it just chatting in a convey then it doesn't matter too much. But if you need to rely on it out bush then I'd be replacing the entire cable. The UHF that we're allowed to run is 'toy' power (5W) and you don't want to introduce losses from unnecessary cable joins. We were away in the Kimberly, one guys radio was head and shoulder better than every other set so I asked what he'd done. He'd replaced the coax with microwave grade line and that was all. Makes a massive difference.
Marck
You can add cable but it will slightly degrade performance of the antenna system. Depending on connectors used and how good you are at terminating you could expect maybe .5 db loss. This can be much less depending on what connectors you use. Also remember each connection is a potential point of failure so you introduce potential reliability issues. And add approximately .3 db loss per meter of extra cable so only add how much you need.This will probably be the easiest / cheepest way forward but technically the least desirable.
If you have an antenna that unscrews from the mount or a mount that the cable screws onto swaggie is on the money much easier to buy a pre made cable and replace it. And factory terminated cables are usually done well. The only issue with this is getting the connectors through the firewall the penetrations might not be big enough. Check first.
If the antenna requires you to solder the coax into it this can be difficult getting enough heat to melt the solder and not damage the antenna.
Some of the elevated feed antennas are terminated buy inserting the coax in the base of the antenna and screwing / twisting it in. If this is what you have the length of the exposed core of the coax is critical to the tuning of the antenna. Copy the cable you removed exactly.
Final option is a new antenna if your antenna has a few years on it this will fix your problem and might even show you an increase in performance.
M
Marck
I don't have any experience with f type but I would think that you will have problems. One being that f type is made for 75 ohm tv coax not rg58 50 ohm coax. So size could be a problem. And I would also recon that your VSWR would be shocking.
Bomber2012
Never said use f type, but with similar connections rather than soldering .
cookie64
Hi Noel, personally I would recommend replacing the entire cable, not only will you get losses with "extension cables" but every connection will give you a certain amount of signal reflection which can degrade the signal output of your set and if close enough could cause future issues with the output stage. I would use either LL195 or RG58CU, if your unable to replace the cable and solder the connections yourself then I'd suggest finding a good radio specialist or Radio Ham that can do the job for you
cheers
Marck
I just had a look at jaycar and they have a compression style N type connector not sure if you need to solder the center pin.
Where is the OP located ?
Buxter
Hi Noel
Haha Swaggie
You shouldn't mess with cables, but I can, and have with success.
This You Yube clip will help
also
GaryM
I reckon the difference if done right is maybe 97% instead of 100%. Buy a good joiner, not the nasty plastic ones, and it should be OK. Im pretty sure I got a solid metal threaded fitting from Jaycar. You just need the PL259s I think they are, back of the CB style terminations, which they also have, maybe it came with them but I think I recall having to pay for them on top. Under $10 anyway. Still need to solder and keep the layers 100% separate. As someone said, no fine little wires touching the middle one...not one. Keep it neat and trim excess.
http://www.jaycar.com.au/uhf-double-female-joiner/p/PS0690
Its basically a pair of back to back SO239s as found on the back of your radio that take PL259s. You put PL259s on both ends of the wire, and connect via the above linked unit. Its a good join, good enough for the aerial in the first place anyway. There would be losses, but I doubt they are significant.
I ended up swapping the whole aerial over because Im anal, but I keep it in the glovebox for emergency use. But when i had it in the cable I never noticed any abnormal reception, and heard no complaints about my transmissions.
cookie64
Haha Swaggie
There are a couple of issues that I see with his methods that I won't bother going into, but I would still suggest that unless you are very proficient with soldering, I would replace the lead as a whole assembly. There may not be an issue with the job immediately, but if you do overheat the centre dielectric and then the centre join breaks due to a dry joint, you have the potential for a short and that may destroy the output stage of your radio.
Just my thought
cheers
