Have a GU 07 patrol , and want to get a second set of mags for on road use to look cool. Want to run 315/75 R16 hopefully in a ATZ . Need ideas on what brand , what styles , off set , any shit you all might know !
Hey mate youll most likely have to raise the suspension 2 inch so they dont scrub
Im running 305/70/17 atz Mickey thompson.
315's! Your probably gunna need a 50mm body lift and a 50mm suspension lift. Very wide tyre for standard suspenion to handle. Mine are 255/85 and they drag at full stretch.
More info on 2'' ( 50mm ) body lift ? Is that just putting spacers under the springs ? If so , will the old man shocks handle it ?
Because of the width of the tyre, A 2 inch lift will note cope with that width of tyre. You'll need more clearance up and down and siewidth as well. So when the spring is compressed, there will be room for the tyre inside the mud guard. A body lift is when you put spacers between the body and the chassis to gain a liittle extra clearance. You can do a bigger suspension lift, but will probably find it illegal.
Do you really want a tyre that wide?? Have you priced one?? Also. there's heaps of extra load on your steering and drivetrain componants with a tyre that wide. Don't get drawn into something you don't need just cos it looks flash.
We were in kempsey the other day, just thought I'de mention that. And Lee locked her keys in the car.![]()
Have a 2'' old man done . How do you find the MTS ? Do they run well on all surfaces ? Good millage ?
There great man no scrubbing at all. QUIET on the h,way.
