mn triton lift
ToughTriton
hey guys
got a mn triton and am looking to upgrade suspension was thinking of just a basic 2inch lift and possibly wind up the torsion bar to give some more lift in front... what else could i do to get as much height and flex in my IFS???
Not sure about Triton IFS front torsion bars, but you can wind them up, or as with mine you might be able to get hd torsion bars, if your front is a little heavier with accessories.
It was explained to me that if you just wind stock torsions up, and a bit of weight on, the ride can be soft / bouncy.
The hd torsions are only a fraction of a mm thicker.
I only have the front nudge bar on the Ranger, couple of spots, 2nd battery is in the cab, so if I was doing mine again, I might have just wound them up, but I got a 2" lift package which included the hd torsions so fitted them.
So after all that and getting the front up about 30mm and rear up 40mm with new leaf packs, I have ended up taking it down to about 25 front, which has the IFS wishbone right in the middle of the upper and lower bump stops, you NEED to have as much droop available as compression, so in the middle makes sense, and your CV angles are more reasonable.
I would go for the 2" lift, maybe if you aren't adding a lot of weight up front you can leave anything in the way of hd torsions, and just wind the front up a little.
Personally feel that with some trip load and most of the weight mods in the back (canopy, tub liner, roof bars / rack, drawers, aux fuel / water, tow bar) having the lift higher at the bac kevens out, mine is really level with a normal outback trip load on.
I would then just got up a level in tyre dia, maybe another 1" or 2" max to keep it legal in the eyes of roads people and your insurance.
The rolling dia increase in rims / tyres gives you some real lift under the diffs, nad combined wiht the smaller suspension lift should be really good on the tracks.
Get good similarly longer shocks, lots of options there, 9 stage adjustables are really good o have and soften up on corro roads / light loads, on the blacktop harden tham up for better handling / cornering.
ToughTriton
cheers mate, i plan on putting on a 9500' winch at the front and 2nd battery but nothing in the rear i will be keeping that free for my bike:D
i already have 32's on so you think should just wind up the torsion bars first and see how that goes?
Yeah you could try that, but with a winch bar, winch, 2nd battery, I'd say if they are part of a lift kit, any HD torsions you can get might be nice.
I'd find out what people include in a 2" lift for it, inc shock options, and then weight it up as to the best thing to do, usually a package is best pricing than getting it all separate as you find it is needed through weeks / months later.
Every time you muck with the front end winding up / down, changing torsion bars etc, you need to re wheel align.
Obviously with the bike in the back (and camping gear etc) 2" lift between 40mm and 50mm would be good to get.
I've read numerous posts on various forums from people complaining that their 2" lift only went up 20mm, 25mm etc, so just get a bit of a guarantee that you will get min say 40mm, but even if 30mm you will get stiffer suspension for the load I suppose.
Do measurements yourself at home before taking it in to get the job done, measure from cantre of hubs to under the wheel arch and write those down for later comparo.
