Mk Triton wheel offset?
adampaule96
hey guys
just wondering what size steel rim is best for stock suspension on an mk triton?
what size? 15 or 16 inch?
what width is best?
and what offset is the best without flares and stock suspension??
Cheers in advance! - Adam
Mr Man
I run 15" rims with 31" tyres on my MK, they are a +10 offset. I have flares, they tyres would stick out a little without them.
marty e
Adam do your wheels locate on your wheel nuts or on your hub. If they locate on your wheel nut you won't balance them
Sent from my HTC One XL using Tapatalk
adampaule96
i think they locate on the hub? if i know what your talking about.. lol..
do you mind explaining it a bit better? and why they wont balance if they locate on the wheel nuts?
cheers
marty e
Well the hubs are made to locate on the wheel nuts and the steel rims are made to locate on the hubs I have been there so I got aluminum rims
marty e
Aluminum wheels have more meat where the wheel locates on a steel rim is very thin the wheel nuts have to have a bevy on them as well and any movement on the wheel nuts puts out the balance
skully23
hi mate i run the same as you with my tyres been looking for flares to fit. just wondering what flares u have
Mr Man
I'd guess they're factory ones, but i can't be certain as they were on the ute when i bought it second hand. They are fibreglass, if you want a photo let me know.
Cheers.
Mr Man
Excuse the dirty wheels. I've been down the river today :)
Grey Ghost
The GLXR and GLS MK Tritons came out stock with flares fitted so you can run wider wheels. I had 31" with 10+ offset Sunraysias on mine but couldn't go bigger than 31 x 15 tyres without doing a body lift or raising the front suspension to its limit etc. I also had no issue with getting either the steel rims or the factory alloy rims to balance, apart from when I had them filled with dry mud...:eek:
dochol
Banned
Hi this is my 2004 Mk Triton with 31 x 10.5 x R15 with a 50mm suspension lift
bilko11
so 16x7 with zero offset brings wheels flush with flares??
as i want to get wheels for my mk to be flush not sitting in to far like factory alloys
