Mitsubishi Pajero, 1995
Good Points
GOOD POINTS: cloth/vehlouver? interior,front seats have arm rests, 3 12v outlets( two in the front, 1 in the cargo bay), cruise control, air con.... when its working, LSD rear diff
Bad Points
BAD POINTS: IFS no travel, regularly picks up wheels
What mods have you done?
over time i slowly added a snorkel, 2" suspension lift (tough dog springs. rancho shocks, rock crawler h/d torsion bars), wound up torsion bars to match rear.
winch bar , 2" body lift fitted
i run black GU patrol 16x8 rims wrapped with whateva cheapest for daily duties
For off road duties i have 34x10.5r16 simex jungle trekkers on 16x8 80series rims.
Things on the to do list:
12000lb winch, fitted
rock slidersfitted
driving lights/led light bar,fitted
roof rack/awning,
LOKKA front diff lock, fitted
UHF/aerial, fitted
rear tube bar
rear 1/4 chop?. chopped
turbo back2.5" to 3" exhaust(what Eva fits best i guess)
up the boost.
Rear diff locker(air or factory vacuums locker).
low range reduction gears,fitted
gauges (oil pressure, volts, pyrometer, boost). fitted
35" mudies.
Why did you buy this vehicle?
it was cheap, and it met my needs at the time. 1: turbo diesel 2:wagon & 3: manual,
How often do you go offroad?
often as possaible, at least once a fortnight.
patrol propply
Good Points
Bad Points
rock slidersfitted
roof rack/awning,
UHF/aerial, fitted
rear tube bar
fabbed up & fitted
rear reverse light/work lightrear 1/4 chop?. chopped
up the boost.
35" mudies.
patrol propply
417646_10150604006617253_642822252_9066758_573438579_n.jpg102.2 KB · Views: 297 -
548431_10150660556352253_642822252_9266647_664082946_n.jpg100.5 KB · Views: 265 -
