Mitisubishi Pajero 1993
PAJ
SAS'd Mitisubishi Pajero 1993
Mitisubishi Pajero, 1993
Good Points
See below pictures
Bad Points
What mods have you done?
The Pajero now runs Jeep diffs after the Solid Axel Swap, 35" Pro Comp muddies, front Air locker, rear Detroit Auto locker, 2.85 transfer gears
Not much, just keep fixing the parts I break
Why did you buy this vehicle?
How often do you go offroad?
Most weekends
None
PAJ
Just some pictures of my rig
bmurray2250
I like the Paj, don't think I go to that extreme with the vehicle but it is very impressive.
Looking at purchasing a Paj in 2011 when I find one in good condition. Hoping for diesel
PAJ
well at the moment the Paj is off the road due to transfer issues, I've stretched the chain and due to the driveline angle on the front shaft I have worn the output bush out. So the plan is to strip the case and try and find a stronger chain and also put some freewheeling hubs in the front. Should make the front bush last longer as its not a replaceable item.
I'll throw some pics up of the rear setup with the Dana 44 in the coming days
Gus
Good to see your still lifting a front wheel..:rolleyes: some serious flex their great stuff..
Gus. ;)
PAJ
Is anyone good with photoshop? I want to see what the Paj would look like as a dual cab? Can anyone help??
PAJ
After testing my sick paint skills, I have sort of what I want to do below. What do you think?
And some pic's of the rear setup, standard 80 series arms, Koni shocks
Big Matt
Mate looks good, id shorten the tray a bit if possible, but would be a good mod to do, not to mention unique
PAJ
Yeah the tray will probably be shorter but due to my suck a$$ paint skills this is the best I can come up with. the tray will ony be about 38" long.
PAJ
going up in the wet would be bad enough, thats what casued the dints in the rear panels last time.. ahhhh the memories, I love that track :D
Big Matt
Im looking to get a toy i can kill soon
I like my patrol to much to kill it just yet, and if i did the wedding would be off
My sweetie LOVES the patrol
PAJ
Hey Guys, well since we are saving for a kitchen and I don't have the funds to fix the Paj I found a old HZ steel bullbar and decided to make a rear bar for the Paj. So here is the begining, I've only done the main bar, I'm going to checkerplate the top under the back door and when I do the rear quater chop (roughly where the clean line is) I'll run some tube under the quaters and mount the mud flaps to that. What do you think??
