Misubishi Diff breathers
Grey Ghost
For anyone with a Triton, Challenger of Pajero, I have just finished fitting extended breathers to my Triton.
The front diff on these units has a nifty little breather cap which push fits into the casing so there is nothing to screw a new hose barb into. To get around this I did the following:
Took the front casing off the diff (its hidden behind the lower bash plate under the front of car)
I took the casing down to my nearest ENZED outlet (ENZED Australia - Mobile Hoses and Fittings Service) where we soldered a 3/8 to 1/4 inch BSP thread reducer into the hole left by the removal of the breather.
I then locktited a 1/4 90 deg. barb fitting into it to run the hose from, as there is very limited room for a straight barb out of the diff. **CAUTION test fit the modified diff casing before you locktite the barb in to make sure you will be able to fit the hose afterwards!**
After that it is a simple matter of running the hose up to the firewall to a convinient high spot along with the rear diff breather, which should already have a tube coming off it but only going into a cross chassis member just above the back wheels.
Made up a set of breather filters for both front ad rear diffs, screwed it to the fire wall and all done. :)
grit
For those not wanting to go to the expense of those pretty blue filters, a standard fuel filter $4.95 connected to a "T" junction will work for both front & back diffs and takes up no more space on the upper firewall.
The purpose of a diff breather is to keep water from entering the diff, which may occur when the diff is hot at the time it submerges into cold water at creek crossings. Most diff breathers work fine at keeping cold water out of the diff. If you have any concerns, run the existing line to a point high enough to be above the water level of any proposed water crossing. The addition of a filter will keep any possible contaminants out of the breather line. Some have breathers for starter, transmission, etc.
I have had my bonnet under water on many occasions (no snorkel) and the diff oil shows no signs of water impregnation. It is argued that water could easily enter the wheel bearings and seals well before working its way down the stock breather lines to the diff. It's worth considering the effects of cold water on hot brake discs when crossing creeks during more intensive 4wd'ing.
Grey Ghost
If it wasn't an item we stock at work I would have used a fuel filter but seeing as they were there I thought I'duse them to pretty it up a bit. And with Mitsubishi's the front diff just has a breather cap on it, with a little one way valve in it, but like lots of little one way valves, once it gets dirt in it it becomes a 2 way valve and might as well be an open casing on the diff. After the Middle Earth trip when I was de-sanding the underside of the ute I realised how high up under the bash plates water had gotten (including over the diff casing) and thought it was definately a better option to do the mod.
bmurray2250
I use a fuel fitter in the Prado for my rear breather and it now sitting inside the rear quarter panel
rodw
Got to admit I went the fuel filter path myself but those breathers are really nifty and neat!
bmurray, I was going to do the same thing as you have done with the rear breather as this is where the factory diff breather was on my Vitara. Anyway, the boys from Ontrack 4WD told me I wasn't allowed to do this. They reckoned the most likley place to get immersed was exiting a creek bank on the far side. Under these conditions, your tail is probably stuck underwater so the breather will not do it's job. That's why they recommended mounting the breathers on the firewall. Not much more work to do this. I teed in to the front breather as well so only used one fuel filter.
Grey Ghost, I heard that modern diff oils can react with the brass fitting but not from any authoritave source so don't know if this is true or not or f it can lead to damage. Anyway, it was enough for me to use the genuine Toyota part to replace the breather in the rear diff....
Golddigger
Triton Diff Breather
Need to put diff breathers on our 05 GLXR Triton looks like the rear is ok. Had a quick look at the gearbox can't see any hoses anyone fitted these to a Triton Any help would be great
Grey Ghost
Thanks Guys for the help, GreyGhost will look at the front diff on the weekend great help
If you look at the rear diff you will see a tube off the top of it going into the cross member, thats the rear breather I extended.
OGJON
my front one from stock ends up @ the top of my radiator & my rear goes into the cross member above the diff
been meaning to get some hose from bunnings & re-route my rear one to the engine bay
do you guys think 5-6 meters of hose should be enough?
for a LWB '97 NL GLS Paj(Terracan)
the tin man
Grey Ghost, you said you had the new fitting soldered into the diff housing. Was that normal solder or did you have it brazed in.
the tin man
Can anyone help me in finding the Breathers on the Gearbox and Tansfer case of my 05 Diesel Triton would be appreciated. I believe I may have to remove the floor panel over the transmisson tunnell. Where would I then look and how would I recognise the breather outlets. Thanks Stan
triton05
Tin man I just had my gearbox out not that i was looking but there is a breather pipe that ran into the rubber boot on the 4wd gear stick under that floor panel my car has been through alot of water and box and transfer oils were water free so far,I had to change the clutch and thrust bearing as the rubber inspection cover came out of bell housing and mud and water screwed up bearing and clutch .$50 for both new rubbers much cheaper than $600 for clutch.
Grey Ghost
Tinman, I've had the grey one through all kinds of crud and riversand haven't needed to fit a breather to the gearbox, I'm more in need of better door seals :rolleyes:before I try to find those breathers.
the tin man
I fitted the braeather to my rear diff this morning. Very easy. Then I removed the centre console and plate around the gear levers. I found a pipe leading into the boot around the Transfer lever and this goes forward to a point where it goes into the Transfer case with a T section and then continues further forward possbly to the Gearbox. This is obviously the pipe Triton 05 talks about But it appears to service both the transfer case and gearbox. Does this sound right. If this is right then the breather to the gearbox and transfer case is also quite simple with the only difficult one being the front diff.My mate is having all the breathers installed in Toowoomba today and they quoted him $400 and 2 hours work. Stan the Tin Man
the tin man
Fitted the gearbox breather, the hose from the box is a strange size but I managed to get a fitting to join it with another hose. Now all I have to do is the front diff. I have to wait untill I can use my wife's car to take the cover into town to have a fitting brazed into it. It has been suggested I also do the fuel tank filter, but have no ideas as yet.
