Some important things to consider before making a deep water crossing..
1. If components are hot and get dunked into cold water they will suck in water. Diffs and gearboxes should have extended breathers and if possible let cool down a bit.
2. No matter how well sealed you think the vehicle is if the water is above the floor level expect it to enter the vehicle. Put things up off the floor.
3. Preparation is the key word, always have a contingency plan. Run the snatch strap to recovery points 1st and tape up on bar clear of aerials, spotlights etc. Make sure the other vehicle is ready if things go sth.
4. Never, never turn the vehicle off if you get stuck. Big $$ to fix a hydraulic'd engine.
5. Try not to use clutch once in the water, select appropiate gear before entering.
6. Walk the crossing. Rocks, washouts, logs can all hinder or stop forward movement..
7. Remove number plate. It will bend up or tear off.
Hope these tips help. If you want more just Youtube Nolans Crossing. Quite a few bad experiences and lessons learnt the hard way.
