Map Apps Whats a good one
DBTouring
Hi every one
I have been looking in to the 4wd Map apps Iphone & Ipad
they seem to all have mixed reviews
I am leaning to the Hema Topo off line, & use it on the IPhone & IPad
Any thoughts out there
David
I've looked and looked and looked and keep coming back to Memory Map or OziExplorer.
I like Memory Map because you can use it on IOZ, MAC, WIndows and Android with free software. You pay for the maps.
It will import and geocache maps ( PC version) and you can use the maps on all platforms.
If you go off the beaten track then anything based on Open Street Maps ( OSM) is just dangerous, useless junk.
DBTouring
Thanks for that
I have been looking at the Memory Maps
I will have a better look
Memory Maps and Hema 4WD are same same but as Boobook said you can import other maps into MM whereas you can only use Hema maps with Hema.
I have the Hema 4WD app and happy with it but would probably go with MM if I purchased again to give the option of using other map sets
DBTouring
Thanks
looking at what I can look up & they are the 2 main one to use.
Alby. I reckon you can use other maps. There is an article about it on the memory map website.
I also have hema 4wd which is ok. I’ve been using maps.me (open source off line) for a few years in pretty obscure places and more than once it has proven more detailed and more accurate than the name brand mapping services. It is free and I’d recommend having it as a backup plan at least. It is remarkably similar to the old shonky maps so there may be something in that.
DBTouring
Thanks for that
will looking to it as well.
