Maf re learn procedure
Jorg
Maf sensor re learning 2009 4x4 bt50 3.0l
I had this posted elsewhere but photos won't upload any more.
I cleaned the sensors and my fuel economy went from 10l/100km to 12/100km hence the hunt to find the Maf re learn procedure.
Before I start
“ Extreme “ caution should be exercised with the following procedure because the engine revs up by itself up to 2500rpm .
1/ Warm engine up to running temp “above 82”
2/With engine running diagnostic port pinout “TEN” short to ground 5 times within 5 secs.
this socket is near the firewall next to the wiper motor, flip the grey cover open to expose the socket
3/ if 2/ is done correctly glow plug light will be on then within 30secs the engine will rev up in 3 stages from idle up to 2500rpm.
It will repeat once more through the revs then the glowplug light will flash for about 5 secs then goes out.
If engine water temp drops below 82 the ecu aborts the learn after one rev session and the glow light goes off.
4/Turn ignition off wait then restart “done”
5/ use this at your own peril It worked for me and I could not find anything on the net so decided to future proof myself next time I look.
99pc chimpanzee
Hi,found this a while back,done on a pk using obd2 port which left floorwell drivers side up near heater,anywhoo,you can scroll to the 3 minute mark for the relearn procedure,cheers
Jorg
I had this posted on another forum a 1 1/2 years back. but after a failure in preserving the images uploaded in most of the threads has prompted me to upload the info here.
Using the dlc-1 socket is a bit more dignified than hanging like a bat to look at the obd2 port under the dash.
I leave a short wire grounded under a bolt near the socket so at each oil change I perform the relearn.
99pc chimpanzee
Yeah jorg your information is excellent,the pictures/diagrams also,yes hanging like a bat,thats exactly how it is I also need a magnifying glass for obd port too at my age,its good for people to see how engine behaves during relearn also
#6
Do you have a photo of the exact location of the diagnostic port socket?
I cant find anything resembling a grey circuit box near my wiper motor? Mine is a 2008 BT50 not sure if that makes a differnce?
Before I start
View attachment 53464 View attachment 53465
Jorg
sorry for late reply mate notifications are not on for me. mine is Auto maybe that's why you may not have the same port.
if not you have to use the obd2 under the dash.
Ozbush Electronics has an obd2 port relearn module, I have one, works great.
From memory mine was about $60.
Google the name it’s a good bit of kit for occasional use when needed.
LazK
Hi Fellas, this may seem like a silly question but just wondering whether the car needs to be in a specific gear when doing the MAF relearn? I've got a 2011 PK XL 4x4 Auto, so whether it needs to be in park, neutral etc. Thought I'd post in here because I've been reading a lot of these PK forums and have found them very helpful. Especially your posts Les! Cheers!
#12
In Park or Neutral.
Has worked either for me.
99pc chimpanzee
just to remind you to warm motor up to operating temp before doing it
Jorg
I also believe the car needs to be driven for a minimum period also.
I've had times it was at temp and didn't work, persisted by driving it some more and it worked.
I would only perform this in Park(auto) with the handbrake on.
