LPG -yes or no?
robsthing5707
G'day all,
I am looking at getting a 80 or 100 series soon, never been into 4wd.
I have heard LPG is cheaper yet your truck uses more and is under powered, is this enough just to stick with petrol/diesel alone?
If not, do these conversions have a time limit before new tanks or parts are needed?
Whats a good thing to look for IF it is a go....
Thanks Guys - Rob
Silver_Bruiser
Hi Rob
I dont know about anybody else but I run my 100 series Auto perol on LPG and its tuned to run better on gas than it does on petrol and still saves big bucks at the servo. I tow a caravan and have a tinny on my roof too....eats up the hills and is great off road. If your going bush its a good idea to check the lpg website LPG Australia they have lots of help and the site might answer some of yoyr questions.
Richard
G'day all,
Thanks Guys - Rob
darthvincor
G'day all,
Thanks Guys - Rob
Based on my non-expert and very limited experience with LPG, I'd say no.
I owned a ford courier 4x4 with lpg for about a year, and though it was a good car and cheap refills at the servos are great, I'm still not a fan.
Here's the reasons why:
-Car was designed to run on either diesel or petrol, and adding an lpg system changes the original setup and allows the car to do something it wasn't designed for.
-Gas converter seems to be (based on my limited experience) its most fragile part. It warms up the lpg by having the engine coolant run through the converter. As a layman, I'm baffled by this system: running icy cold lpg and boiling hot coolant in the same component. Of course it works, but I'm surprised they couldn't come up with a different method.
-Not all mechanics are qualified to work in lpg cars, means less choice in mechanics.
-Lpg system requires about 10-12 additional parts: more parts, more things to go wrong.
-And finally, I reckon its a 'band-aid' technology. Higher fuel prices, so as an interim solution before hydrogen or electric cars become available, you can slap on an lpg system.
That said, I think designated lpg cars that were designed to run on it are a great way to go, but slapping on an lpg system to an old diesel that's been chugging down diesel for decades...? I wonder.
(so, obviously I'm biased against lpg, but these are just my two cents ;))
discomick
G'day all,
Thanks Guys - Rob
personally i'm not a fan of lpg.
my mate has an 80 series and he bottoms out a bit where the tank goes.
having said that the guy from 4wd tv has a red 80 on gas and he does alright maybee email the show and ask the question, they're now on foxtel ch 183 thursdays at 3:00 and 10 now known as your 4x4 check it out.
Jarh73
"Gas converter seems to be (based on my limited experience) its most fragile part. It warms up the lpg by having the engine coolant run through the converter. As a layman, I'm baffled by this system: running icy cold lpg and boiling hot coolant in the same component. Of course it works, but I'm surprised they couldn't come up with a different method."
Its called a heat exchanger and is pretty much universally used throughout industry and automotive applications.
Rather than an air to liquid heat exchanger such as your cars radiator its a liquid to liquid heat exchanger.
Very typical and well proven technology.
Can fail due to air locks, insufficient coolant, corrosion or blockages pretty much like any heat exchanger.
Justin
BUSHNUT
It depends on what travelling you want to do in a 4X4, if it is commuting then LPG is fine, I have had a 60 series cruiser and a GQ patrol wagon on LPG/petrol and for out in the suburbs and up in the high country , both ran better on gas than petrol due to how I wish to be tuned .
On the Jap motors be prepared to overhaul the head about every 260.000 KM's if going to run on gas.
If going to tow caravan or going to tour central Australia or do any desert trips then there is only diesel as your option , whilst LPG it is getting out to the main routes now, it is a premium , the muck that they dish up as petrol ( OPAL ) in the indigenous areas is a bugger for all your emission control gear ( very expensive to replace ).
LowLux
LPG has its pros and cons. I have a few problems with LPG (hence why I stick with diesel) and here are my reasons. 1) Your vehicle can only be tuned to run best with one or the other and not both 2), there are not as many fill up stations for LPG when you head bush, 3) it takes up space in or under the vehicle, 4) it's an added cost to fit which in turn will take a considerable time to re-coup the savings, 5) In the not so distant future, the government will be removing the subsidies which makes LPG cheaper and make it desireable now, 6) I don't believe its as safe as petrol or diesel. Good luck with your decision.
bubba
I'll add my two bobs worth.
If running a petrol engine I would use LPG (LPG/Petrol not a dedicated LPG)
If you do go lpg use an upper cylinder lubricant. But remember you need petrol for when you can't get LPG in the more remote areas. For this reason I currently have a diesel.
If I were running petrol as I have in the past I would,nt be without LPG. (only because it is cheaper)
I think like all things you need to determine your specific needs and ensure whichever set up you use it suit your purpose.
Bubba
Silver_Bruiser
Hi again Rob
My whole point is: My question would be: Are you using this vehicle for lots of off serious road bush/water travel or towing a caravan around Australia ( a few times) OR is it a regular every day vehicle that Mum & Dad drive with the occaisional off road bush/water trip and regular caravan towing?
If it is YES to the first and you can afford a diesel and the wife is happy with the smell and the dirty job of refueling and put up with the constant oil changes and the VERY high cost of diesel then YES I would definately go for the Diesel.
If its YES to the second then like me you will settle for the Petrol/Lpg version and enjoy yourself for less and keep the missus happy to boot.
As I said before I have run Petrol/Lpg for over 25 years and yes in the early days it wasnt much good but these days things have improved vastly especially with the Injection models and computers that enable your beast to run well on both fuels.
I run a 90 litre useable tank under the rear I get around 400 klms towing the van it costs me around $26 (.27 litre) to fill her up on lpg the worst it has cost me is about $50 (.50 a litre) REMEMBER that when lpg has cost me more so has the Unleaded (and Dieslel)
I have been doing off road stuff for years in a duel fuel rig and towing my caravans and boats all over the place and yes there are some instances when I wished I had a diesel but that is in extreme conditions.
As for Diesel/lpg I have yet to meet anyone that has had it for a long time (2-5 years) to get a descent idea on its worth.
As for mechanics, these days you will rarely find a town where someone can not help you and at worst you switch it (lpg) off and then get the mechanic to fix the petrol side (duh).
Good luck which ever way you go and ENJOY your 4wd :D
Richard
G'day all,
Thanks Guys - Rob
bmurray2250
A club member has a 80 series on Gas/petrol and he happy with it. A person in Newcastle I know does the gas upgrade on diesels and recommends it. The economy and power improvement is worth it.
monk2
Hi Rob as one how useto do L.P.G. conversions on early and late model 4x4s the early models yes had a slight power loss not to noticable in manuls but a bit more on auto's, I'v been doing LPG stuff for about 25 years and have had most of my own cars and 4x4s set up for duel fuel operation. Petrol burns with leaving carbon deposits behind it this builds up behind rings and things and can slightly shorten the life of an engine but on the later model stuff EFI wich has a more persice delivery system of fuel this is not so bad, yes heads will require setting up with hardened valve seats to stop valve resession but after that it will give you not much problems,LPG burns with no carbon deposits left behind the engine will do a lot more klms like taxis do with no problems, but like a petrol system it will require servising at requalar times same as servising you car but make sure you keep it duel fuel system. my old wb statesman traveled over 1 million kls mainly on gas,my old 60 series land cruiser traveled over 1.5 million kls mainly on gas, i did the simson, unadada track, the old power line track to the tip of QLD in this old girl keeping in mind that gas was hard to get out back so a lot of running was on petrol, now have a 1989 62 series gxl and again its on duel fuel and got no problems, as for 4x4 tv yes ask them by all means, ask simon from 4x4tv as his shorty now has a gas tank under the back of it as well, if you get to speak to simon say hi for me (Gary) with the old musterd colour 60 from mt dissapountment. 1 TEA CUP FULL OF PETROL VAPOR HAS MORE EXPLOSIVE POWER THAN A COUPLE OF STICKS OF DINAMITE some thing they donot let you know when buying petrol powered engines, this is more explosive power than LPG, if you can handle the smell of desiel and the mess and are plaining a lot of out back stuff then its the way to go
hope this has helped you out some,
regards Gary ( monks )
LowLux
I would use gas/diesel mix (if not so expenisve to fit) because it only injects small doses which is mixed with the diesel hence its not dedicated to one or the other and the engine, that way, is still being lubed by the detergents in the diesel and you can still run with just diesel if no gas available.
LowLux
I probably wouldn't be using Taxis as an example. Taxis clock up so many K's because they are continuously running without much time or chance of cool down then heat up again as the average family car does on a regular basis. They are also being serviced much more regularly than the average family car.
millsy
I am an LPG fan, and have been since'89. I have had six cars on LPG, including the current three I am running at the moment. This includes the 1982 MQ Patrol. Have done about 800,000km with these six cars over that 20 years. And have helped my son and daughter put three cars on LPG.
In all those years I have only had one problem with LPG, and that was last year, five days after I bought the Patrol. The corrugations up near Arkaroola caused a gas leak near the converter. I just switched over to petrol to get me back to Adelaide, and had the copper pipe fixed up with a double flare joint so that it wouldn't happen again. So this goes to show that having two seperate fuel systems on the car can be very handy in remote areas! If your carby 'blows up' on petrol, or some other part of the petrol system - switch to LPG. And of course the other way round, as I did.
I have worked out that in 800,000km I have saved about $60,000 in fuel costs. In the same time I have spent about $500 on two reconditioned cylinder heads, due to valve recession from the LPG, and have had one tank pressure tested due to the ten year rule. That cost me $500, but I think I coud have found a better deal. That same tank was transfered through three different vehicles, and is currently in the VH Commodore. So I am $59,000 ahead. My son did not want to put his car on LPG because his friend told him that LPG wore out cylinder heads! I reminded him he could afford to have the cylinder head fixed, and with the remaining thousands of dollars saved on fuel put down a deposit on his first house!
As an example of the savings, a trip I did in the Patrol last Xmas was about 2100km. That was a mixture of highway driving and four wheeling. Along the Robe beach run, into the Ottways for two day trips, and about 7 hours of soft sand driving across the Big Desert in Victoria, never getting above 2nd gear.
Total cost of fuel was $150, over 7 days of solid driving. Mind you I do have a small 2.8litre motor.
You can say that LPG gives you about a 50% saving on your fuel costs. So as fossil fuels become more expensive, your savings with LPG will increase at the same time! And the larger your motor, the bigger and heavier the rig you drive, then the more $ per km you will save if you are on the LPG. And don't forget the $2000 subsidy. So you will be ahead after about 6 months of driving, or maybe less, depending on your km/week.
And as far as mechanicals go, less carbon in your oil means that there is less wear in your cylinders and bearings, because the oil stays cleaner compared to petrol.
A few things to learn if you get a conversion; If you fit an upper cylinder dripper, which I have on all of my older cars ( I don't bother on the '92 and 2000 Commodores because they have hardened valve seats ), then be careful to get the drip rate just right. Too much can be costly - at about $15/litre. Before you know it you can drain the 500ml resevoir! So safer to just put 150ml in before heading off on a long journey, stop and check after 200km and see if needs adjusting. When you are happy, fill it up. They say it should use about 1ml per litre of fuel.
And if it is an older car, one that does not have a computer, find out how to advance the timing for LPG, and put it back to normal for extended runs on petrol. Only takes about 1 minute to do this on the side of the road. On LPG, if it is too far advanced you hear the 'pinging' noise of detonation (can damage pistons), so needs 'backing off' on the advance. And if not advanced enough, you hear a loud 'exhaust cacoughany', as the fuel is still burning when the exhaust valves start to open. So needs to be advanced a bit more. A bit of practice and its easy!
Cannot advise on the newer models with computerized Engine Management systems. My guess is that all this is taken care of automatically! But check it out. ( My son does not seem to have any issues swapping from petrol to LPG in his VT, and my VR only runs on LPG since the petrol pump is burnt out! )
Cheers, Millsy.
fozzee63
Lpg Go For It!
Go for it! there are some scare mungers :rolleyes: out there on gas, if you not mech minded regular services are recomended (as on petrol and deisel) I'v ran gas for many years on a V8 253 nissan patrol and runs better on gas than petrol good power. to clear up some myths: gas has more power than petrol (it's the system you chose that the problem)
(look up gas reseach Gas Research) bloody good stuff
another bonus if ya run out of water the gas freezes well before the engine siezes.
but do some home work on systems theres a few out there, Look at the fuel injection manifold types. liquid injection is the go, But only on some model vehicles. and yes they gas deisels, More power and better economy and cheap fuel too. hope this help
cheers fozzee
