Interstate the prices tend to be 15 to 20 cents more expensive than Vic.I don't know where you live,gas is .529 and petrol is 1.17
That must be why Y62 Patrols are selling like hot cakes and there are 10 times more petrol 200 series cruisers being sold.Diesels cost more to purchase,maintance is more often,parts are more expensive,and the new era diesels running 30000 psi injector pressures cost a fortune for one injector,and reliability when the kms mount up is a problem,but if you live in the outback,or do a lot of trips out there then diesel,but most just drive around suburban areas ,it's false economics,ask a good mechanic about the new era diesels,cost of parts will blow your mind
I have a dual fuel system. The gas is an Impco system and I have electronic ignition fitted so it runs perfectly. Starts easy, idles smooth and runs smooth.Hi guys/girls!!
Just wondering what sort of kms per Lt you get from your LPG? My 80 series has a roof tent, but I suspect something is up as my 85lt tank yielded just over 300km, and I don't think this is right. Am I wrong? Cheers
I can beat that. Along the beach at Rhobe to the mouth of the Murray, 120km, went through 60ltrs. 2km per litre or 50l per 100km.worst I have seen on soft sand towing over a ton of camper it is up to 35/100
Yeah. My Troopy pinged a lot on petrol. I guess it has to do with tuning to run on gas and then petrol is a bit more advanced in the points??? So I fitted an electronic ignition which starts, runs, on LPG really tops. However Petrol still runs on a bit so I use it on the highways because if I back off in town it does create a little back fire at times.wow diesel less than $1.00 /l that's cheap, about 1.20 here, yep hear you Rog LPG can be hard to find when doing the back blocks but that's why I put the sill tank in and take a jerry or 2 on the really long trips, that gives me 170 l petrol
For the most part the Disco is on BBQ fuel so its as cheap as chips to run now that its well sorted but down side is it needs premium fuel so it doesn't ping its head off
Diesel was 95c for a bit over a week in childers, now its up to 102 but its been sitting around 100 for a while now. Cheaper in small towns than the nearby cities here. Petrol is dear though.wow diesel less than $1.00 /l that's cheap, about 1.20 here, yep hear you Rog LPG can be hard to find when doing the back blocks but that's why I put the sill tank in and take a jerry or 2 on the really long trips, that gives me 170 l petrol
My old 4Y ran better on e10 than anything else i found. I used to get 450 on e10 and only 400 on 95.Strange, mine runs better on lower octane (cheap) petrol.
For the way I use my car (weekends and short trips, plus everyday city driving), petrol/lpg is perfect. I'm paying 56c for lpg at the moment, so my 2.7 tonne 4.8L Patrol doesn't cost much more than my wife's Corolla to run!
Can you tell us why you don't like the injection systems?There are number of systems that will change your open loop to a closed loop. It depends whether you have a impco mixer that has the power adjustment built into the mixture or the more common type where the power control is in the line between the convertor and mixer. The later is more simple where the power adjustment is simply replaced with a solenoid that adjusts its mixture based on a small ecu and O2 sensors in the exhaust. For the impco mixer, like mine, it involves a small solenoid that increases or decreases the vacuum applied to the mixer diaphragm to adjust the mix.
You can see the various units here; http://www.alternatesolutionsgroup.com.au/LPG-Fuel-Processors.htm Mine is the CP401, the second one on the link.
I do not like the vapour injection systems and would not put one on my car.
