Personally, i check my nuts after 1000kms,
So What most of you Guys are saying I paid for a Service IE new Tyres Over $1500 and its ok for the dealership not to forfill thier Dutie of care to the customer and let the vehicle on the road unsafe . How would i stand if i had an Oil change and no Oil was replaced ((((((( still my Fault???????????????
Thats great mate testicular cancer is a huge issue and great too see others check there nuts at lesser intervals...
On the side of alloy rims,ive run my 31's with MTZ's for over 4 years,never had a puncture or cracking etc etc...
Ive hit rocks harder than i would have liked and on two occasions cracked the seal on the bead causing about 2psi a day being lost..But after taking it too a Tyre place and being reset its fixed the problem...(oh they wanted to put an inner tube in them,i declined and said put it in your bath and see)..
I would recommend alloy wheels out in the bush anytime.Well especially Toyota's..When i first started i was nearly scared into buying steel rims,was told i was going to have all sorts of issues.But none have eventuated...
Goodluck
Not saying its your fault or there's. but it's your car. You should be checking it. Do you let ppl hook up and tie down trailers for you too without checking its done right. It's a bit different with things you can't see ( oil change and brakes stuff like that ) that where you have to trust your chosen repairer to do the right job.
To do 2500 km before they came loose is to far to say its the tyre shop I would think. I'd say they have done them up but it's just come loose when they bedded in. They should of told you to check them or bring it back in 500-1000km.
I don't mean to sound like I'm having ago, but we are a " Blame it on someone else sociaty " and I get sick of it. Things stuff up. Doesn't mean it's someone's fault all the time. Any who that's my rant.
I would never have alloy rims in the bush again. They don't hold the bead as good as still rims do, and if you do manage to bend a steel rim at least you can normally fix it out in the bush.
Paul patrol had alloys rims on he's Datson and he's had a wheel fall off before from the alloy compressing. He has to re tighten he's every 2-3000km.
PK
I never had nuts come loose when I had alloys as well. But I did damage a few and they costs me heaps to repair. Where I steel ones now I can just hammer straight again. That's on the ute anyway. I've got a new prado as well with alloys and I've never had a problem with them.
I think it's just of the draw sometimes.
PK
