Looking into a 2010 Challenger
red hilux
Right.
Im thinking about getting a Challenger.
I would really appreciate your thoughts.
Good points, bad points, what to look out for etc.
Do they all have factory rear locker or is that an option??
Im thinking about sell ing the surf, hopefully get enough money to put a few things on it right away.
Looking at lift, chip, winch, rear bar, under body protection, front locker (hopefully rear locker is in already)
Toddyh
I've got one. Link to build thread is in my signature.
Good points - they are cheap, the 2.5L motor is no powerhouse but it's as reliable as they come. There's no DPF which is one less emissions thing to fail. They will fit 32" tyres in factory form. Heaps of Tritons out there mean parts are fairly easy to come by.
Bad points - the airbag wiring loom will fail. it's a widespread fault. It will most likely already have been replaced after warranty. There are other less common faults such as the 3rd gear synchro wearing out too quickly and oil leaks from the turbo. Both can be easily checked by driving or inspection. Another big deal was that a batch of engines had machining issues which resulted in overheating. Mitsubishi did a recall test where they stresses each engine trying to cause a failure. If it failed, new engine under warranty. If not you're good to go.
Almost forgot the auto is pretty poor. If you never tow you probably won't have an issue but if you plan on towing it has a tendency to overheat and cause fault codes. The manual is reliable but probably slightly too highly geared.
Only the LS and XLS have the rear diff locker in 2010.
As for your mods, talk to Ultimate Suspension for the lift and Bushskinz for the bash plates. Those guys are the experts in their fields for Challengers.
If you chip it make sure you get an exhaust too.
Kaymar is the only rear bar supplier other than getting a custom bar. I have the Kaymar and couldn't be happier with it.
Gavo
I was going to do the whole "talk to @toddy thing" no need.
I've done a shit load of trips with Todd's challanger. Even towing his camper I've always been surprised of where it goes without out too much drama!
Seems to be a few modified ones getting around too!
dezezez
I've got an XLS and I love it. I need the 7 seats for when the in-laws are in town meaning I can take them, the wife and the kids out and we need only take one car.
I've been pleased with the performance both on and off road. Good fuel consumption and as toddy said, the 2.5L TD is no V8 but nor is it underpowered either. Handling is good and it comes with enough bells and whistles to make life comfortable enough.
Mods are easy enough to come by and can fit a good size tyre with a suspension lift.
Cargo area is pretty generous.
The main downside I reckon is the size of the fuel tank - 70 litres is pretty small but combined with good fuel consumption is not super bad. There are some good aftermarket long range fuel tanks you can fit but you got to sacrifice the spare tyre well under the boot.
Toddyh
You can get a replacement tank from Opposite Lock. I believe it's 112L. Apparently because it's square edged it means the last 15L or so is not usable. But that still means a roughly 30L increase in usable fuel capacity.
dezezez
Hi Toddy, that's sounds pretty good.
Any idea of cost?
red hilux
all good dude, more you hijack with questions, the more I learn.
3rd gear syncro, thats not a prob, Im after an auto anyway.
Do you have any more info on the auto problems??
I will be towing a 1.3t boat and trailer, I will be doing beach work. Will a large tranny cooler fix the over heating or is it more than that??
Other questions on the top of my head.
Factory rear locker. Any problems??
installing airbag into rear sus
Toddyh
It's not confirmed but the auto issues appear to stem from the torque converter unlocking which causes excess heat. A trans cooler will help but not solve it. The best 'fix' seems to be altering driving habits. Don't just leave it in D. If you approach a hill downshift to an appropriate gear so the engine revs higher, which saves to torque converter from unlocking.
rear locker seems reliable.
I used to have airbags in the rear. I think getting better suspension is a better option personally but others use airbags with no issues.
