Lock Rite Lockers In Gq
rustygq
Hi all
i was just after some feedback on lock rite lockers in the front of a GQ,
how they worked are they worth it,i was looking just at a cheaper alternative to getting air compressor and lockers,an the other reseason im asking is that my friend has arb lockers in front of his hilux and they seem a headache every time he needs to turn just abit,
Do lock rite have the same afect in turning while climbing at a slow pace
an info would be good thanks
cheers rusty
grit
Hi all
cheers rusty
When torque is to both wheels (4wd) they will not click as they do in 2wd in a carpark (for instance). Turning circle is affected by any diff lockers.
I hope you find this link useful
rustygq
hi grit
when u say click when fitted to front and hubs not locked in do u still here this click,i want be driven the car as my every day shopping but just to work at times and camping
cheers rusty
grit
hi grit
cheers rusty
I don't have free-wheeling hubs, but would expect that as the click is from outer wheel turning faster than the driven wheel, and as hubs would alleviate shaft being driven by the wheel, this should be resolved. Just don't quote me on it ;)
grit
It sort of stands to reason that hubs would stop the wheels driving the shafts which causes the clicking noise in the first place. I wouldn't be too concerned otherwise.
rustygq
ya that wouldnt worry me to much ,the main thing is to they work better than a LSD say in the rear and r they just as good or almost as air lockers ???
MMM
grit
MMM
I would personally prefer air-lockers in the back.
Yes, they would work better than LSD as both wheels would be locked.
Results should be the same - Lockers lock.
Air gives you control over when and that is often only when needed.
many smaller capacity compressors are okay for use with air-lockers, so you don't need the best. I personally think the best is 'Endless Air'.
rustygq
Ya i was lookin at air lock later for the rear but for the front was just lookin at a less cost set up with simular result just lookin at others advise from tho's or any1 that has had the lock rite
if i had a spear 3k i would do both air lock but until then im happy to start at the bottom.i must say the gq is better than the old 1990 navara i had buy again couldnt failt that old girl only under powered
grit
I don't see any problem at all with using auto lockers in the front with hubs free-wheeling.
Full Time 4wd vehicles must fit free-wheeling hubs to have front auto lockers fitted, as they can't simply select 2wd mode.
