Lock Rite Diff Locks
KAIBUTSU TORRAKU
I have bought myself a lock rite for the front of my GQ. I guess I was a little naive in believing the advertisement. Now that I have it and the installation instructions, it no longer looks like a job which would take " a couple of hours for a person with some mechanical abilities".
Has anybody actually fitted one, or had one fitted by someone?
How long did it take and how difficult was it? Or, what did it cost?
Looking forward to some help.
Regards,
Glenn
grit
I fitted on to the front of my Jeep. It IS noisier than they have you thinking it will be. Fitting is suited to anyone who is proficient with a spanner. It is important to check spacings and shim if necessary. This job should be no harder than fitting new brake rotors. A good tip is to use synthetic diff oil after fitting, well worth the couple of dollars extra.
KAIBUTSU TORRAKU
Thanks Grit,
I am just a big bit worried about the missing pictures on the instructions and the detail regarding bleeding brakes, removing calipers/rotors, hubs etc, etc,...
How long did it take you to do the job in the Jeep??
Regards,
Glenn
grit
Took no more than 4 hours, more like 3+. Had a friend help - meaning a few refreshments were consumed along the way and way too much off topic chit chat. If you can keep the piston compressed using appropriate clamp (G clamp - dont compress too far or fluid could bleed back into master cylinder and flood over causing corrosion damage) and carefully support calipers to avoid damage to brake lines, there is no reason to bleed the brakes.
KAIBUTSU TORRAKU
Hi PHS,
Yes it came from SA. It Cost $499.00 plus $20.00 postage.
Hi Grit,
Thanks for the feedback. I am trying to line up some "help" who are a lot smarter than me with these things. Also leaning on those with experience to try not to bugger things up too badly.
grit
If you have any doubts its smart to get some help. Experience learned from others can be far less expensive ;)
rustygq
hi glenn
let us know how u went after getting it fitted and tested as i have been tossin up between air locker or lock right,Would be good to get some pr from none selling people
thanks rusty
grit
Mine sat new in the box for a few years before I decided to take the plunge. It WILL reduce effective turning circle and will click in 2wd when cornering (more noticeable when turning tight).
cruiserlad
but you dont notice it with manuel locking hubs in 2 wdrive do you grit its only when you lock the hubs and engage 4wdrive is not
grit
Sorry mate, don't have free-wheeling hubs. The click (when cornering) is from the outer wheel travelling faster, so freeing the hubs would fix that.
cruiserlad
excellent grit theres definatley something to be said for free wheeling hubs isnt there so at least when you lock the hubs and engage 4 wheel drive you would know the locker is engaged
grit
except when you would rather not have to step out into the mud to lock them.
grit
I more often (nowadays) stay in 2wd even on some of the less wild river crossings, due to the aggressive tyres. When it gets extreme I get out to do the dis-connects if not already done. I'm now thinking of just removing the torsion bar altogether as I don't have the need to corner at high speed as much as I thought I did when younger. That way I can do (almost) everything on the move.
cruiserlad
i just lock the hubs once were offroad then if i need hi or low 4 i just engage them so it would be the same with a front locker
grit
YOu will lose a bit of turning circle with locka's, its a small price to pay for the added traction though.
lost4wdclub
Lock Rite
Does anyone know where I can get these installed. What are the main limitations. Can they be used front and rear.
