mighty
Hi,
Seeing if someone can help me in this issue.
I installed a dual battery with aux being a lithium po12v attached to a dc dc charger with setting for lithium/gel/agm/lead.
Battery and recharging worked fine. I checked how long battery takes to dry out with a fridge attached.
Once drained , all the aux system was down.
I check the battery while connected to the box with the anderson plug to the dc dc charger and read 1.6v(odd). Switch on the car and dc dc won’t charge and read 1.6v
i disconnected the battery from the box, checked and read 9.7v.
i put an agm and change settings the agm battery and dcdc work fine and dcdc is charging.
Any thoughts?
Any thoughts?
