Lifting my bravo
Bravoman
Hey there I want to lift my 2002 Mazda bravo is 2" lift high enough or do I need to get 2" body lift as well I have 31" tyres on it and it's a freestyle cab tray back
chris_stoffa
If you are looking to fit 33 you will highly likely need to trim inner guards, a 2 inch suspension lift will give you good clearance on your 31/32's ........... you dont really need a 2 inch body lift unless you are chasing 33's or just want the lift for the look.
Bravoman
Hey Chris does the 2 inch lift on the bravo high at all I have been told if you go 3" you will start braking cv shaft is this correct ?
Bravoman
Yeah no worrys thanks heaps getting 2" inch lift tommrrow do they look good and high enough ?? I have 31" tyres hope high enough :)
Then Going to buy CB radio in it then that's about it I think has your bravo ever made a whistling noise when idling and reving it just before you change gears.
max bravo
hey mate had that whistling sound a while ago had the exhaust gasket replaced as it had a crack (after replacing turbo and inter cooler and taking it half apart )
