Lifting 05 Courier
courier
Hi all i have an 05 courier 4x4 and want to lift it apparently 40 mm is all i can go just wondering are the rock crawler range any good and also rancho shocks?
Pure Yobbo
Hi Courier,
Chase up Zordo on this forum. He is the suspension king. He lifted our Truck amd done a great job. He also just supplies parts if you want them. I'm sure he will answer any questions you have.
patrolpassion
suspension
Hello courier, i to am new to these forums but found them handy. I called Zordo the other day and got a good price on suspension for my 4.2 turbo patrol.
I ended up going with H/D Lovell springs and Rancho 9000 adjustable shocks which lifted it about 75mm but will probable settle to around 50. Could not of been happier with choice but of course if you ask 100 people you will get 100 different choices, in the end it is up to you.:D
grit
Do you simply want to lift the body 40mm, or change the suspension characteristics?
More flex?
Carry more weight?
softer?
harder?
Regardless of other comments I have made on this forum in response to the problems some have had with Rancho 9000's - the general consensus is that they have a fairly strong following. The guys at 4wd1 are a great bunch and I have never heard bad feedback about their ethics & service. Being adjustable means that you have a few choices to try if you are not exactly sure about the type of ride you want to end up with. The reality is that you can spend an unlimited amount trying to get it just right, & if you are happy with the way it feels right now, expensive changes may not be the best option. Being only 40mm, you might just consider simply adding spacers &/or longer shackles. Talk with someone knowledgable about the type of rig you ride & what might work best.
ZORDO
Mate.
Rockcrawler is a good product but you will pay for it.:eek:
Another brand to consider is Bluemax gear at a reasonable price
Leaf springs,u/bolts,bush kit,greaseable shackles & four shocks $900:)
If you want Rancho 9000 adjustables add $360
grit
Do you have the option to also do a body lift?
courier
was thinking about a body lift but can't really see the point behind it plus i am not very tall lol it is all going to change now anyway i am thinking of starting my own mobile fabrication and welding business so i will be towing a trailer with diesel welder gas bottles and all sorts of crap probably up to about 2 tonne plus the back will have tool boxes and steel racks on the roof so i guess recreation suspension is out and have to go for load carrying instead but that is what happens when you wand to make money i guess :)
grit
Sounds like you might need to speak with a suspension guru about stiffening up the rear end then. ;)
Body lift helps make room for bigger tyres with little effect on existing suspension.
