Rigger64
Im having trouble with wiring my LED Light bar in a 1996 Suzuki Vitara, to only come on with my high beam on (Yes i em using an override switch so the light bar can be isolated), the problem is that when i have my lights on the bar will stay off but when i turn my lights off the light bar comes on.
I checked everything twice to make sure i had it right well the Relay & Switch side of thing is all good but it's the trigger from the headlights the headlights have two red with different colours & a white wire with blue marking on it which seams to be an earth but "not" the reason i say that is that when i put the tester in the "what should the Earth" & the other end into the high beam wire & change from low to high beam it switches from Neg ground to Pos ground.
Can anyone help as it's driving me nuts having to insulate the lights all the time
