Leaking gearbox!
hayden94
Gday all,
Im after abit of help. So on the easter long w/e, I did a few watercrossings and played around in the river for about 15 mins (tried gettin on an island haha). Yesterday I discovered water leaking slowly out of the plastic plug at the bottom of the gearbox. So its been a cupla weeks and still draining, I fugure its pretty well full.should I drain and refill the oil, or is there goin to be more serious problems ie rusty flywheel etc. I have been driving it everyday and havnt noticed clutch slippage but it has been abit sticky.
Any help would be grately appreciated
Cheers, Hayden
bluehilux
Banned
Drain it straight away and put new oil in..
If it was mine i'd then go for a bit of a drive to get it hot and redrain it again.
Then invest in diff/gearbox/transfer breathers !
Also it would be a good idea to do the diffs/transfer as they will be full also.
Mattzz
Is the water leaking out of the gearbox itself or the bell housing? (Which contains the clutch)
It's always better to be on the safe side and drain the oil out of your gearbox, transfer case and diffs if you have done water crossings without having breathers fitted.
You will probably spend $100ish on oils but it will be worth it.
I doubt you would have done any damage to the clutch or fly wheel of you have continued driving it.
Maybe......you might have damaged a bearing but you will know when it starts getting noisy.
hayden94
Ok well I cant afford the oils atm, and clutch master cylinder is really on its way out (unrelated) so I dont really want to be driving it too much. How long should I be letting it sit for? Should I just take it out for a spin after work everyday till next week when I can afford the oils?
hayden94
Actually its probably the bellhousing. Its coming out of what bolts directly on to the block, which I believe is the bellhousing???
muc the truck
I dont mean to come across as a ass, but if you play in the mud and watercross it costs a lot more to maintain a vehicle . one thats not had the extra maintenence often becomes a money pit to some one else. all i can suguest is if you do not change oils in a vehicle with breathers submereged the metal quicly cools and sucks in water . this mixes with oils and stuffs the hardening of all bearings and gear surfaces. If you can aford the maintenece then have the fun if you cant stay home and make the truck beter for next trip.
if you continue to play in the mud and water at least join all the brethers form difs, gearbox and tcase to the aircleaner like military and some very good off the shelf 4x4 do. atleast this way you wil never need to change the oils prematurly again as there is no restriction of filter between the cooling diff and the air intake . I dont like people usig sintered metal filters etc as they get blocked up with fine dust and do nothing.
if your clutch fluid is black the slave and master have buggered seals and are braking down causing the black colour . the slave is usually the weaker but the master is never far behind especialy if the fluid goes black again .
hayden94
Havent had the chance to change the oils yet, as this is one those weeks were all payments come at once. Next week im changin all the oils including engine and as soon as I sell my other car I am doin a full service and the breathers are next on the list. I was told that I should be fine as there sealed up really well and the breathers are pretty high from factory. Obviously not.
Also next week the master and slave are being replaced. Driving the old car to work this week.
Thanks for all the help guys, ill change all the oils, take her for a spin and repeat. Then no more water till I get my breathers haha
prawns
this is the kind of noise you dont want if you get crap in your bellhousing like i did
[YOUTUBE]LUzLVSEl8QI[/YOUTUBE]
My clutch now semi-randomly stops working completely (eg if its in a gear, it wont come out and vice versa) so I wouldnt muck about too much and get right on it - else possibly up for bearings and things if its in the bellhousing - Mind you thats not the gearbox I guess but maybe check your clutch fork rubber isnt torn or your inspection plate missing like mine was as well - it let all the crap straight in
hayden94
:( ouch, doesnt that just make your gut sink when first hear a noise like that. The motor threw a rod in my first car on the freeway and when I lifted the bonnet to be welcomed by a massive hole in the side of the block I new I was up for some big bucks. Thanks for the video mate thats gotta be the easiest way to explain it. Mines not doin that yet but ill keep an ear out cheers. So is yours still like that?
prawns
yeah mate mine still does it - got a quote of $700 just for labour to replace the thrust race bearing.
I got a clutch kit which will be getting put in though (thanks to the kind people on here!) once all my parts arrive and some kind of work party is organised lols - That should see it sorted :)
muc the truck
you could have painted your toe nails for the video lol
muc the truck
you wil have to make a video of that , please .
prawns
I was going to take some photos as it progressed, I guess I could do some short video as well :)
I just hope im not jumping in way over my head with this kind of a job as Im a mechanical idiot - and hopefully somebody with a trolley jack volunteers when its time cause one would be handy :D :D
muc the truck
its prety hard to muk around with a video while you busting your giy moving a box into possiton lol maybe give the camera to some one else and forget about it until the jobs done . you be suprised how funy it can be from some ones elses perspective.
prawns
Might leave my iphone handy on the desk for people to grab whenever they want - good idea mate thanks :)
I have light hand tremors too so at least the photos others take wont be blurry is another bonus :D
