Lc 79
jspbp4
Should i go 3" lift or stay with the standard 2" and how hard do i go with the rear springs, don't carry a lot of weight only on trips away.
Don't really want to use air bags but at the moment just looking at the lift.
phs
Im currently running a 2" EFS lift it is great but next time around ill be going 3" there just such a long wheel base 3" is needed I think . when I did the 2" it lifted 75 odd mm settled at about 55mm I have 600kg Constant Springs in the back Thow I'm running a 2.4 m steel tray and decent size steel tool box unloaded its a tad harsh in the rear Thow even having just both tanks full makes it fine if I have a few tools in the box it's ok as well and that's with LT tyres too . perfect for camping levels out fine . Unless I'm taking every ones gear. Then it drops a little below level
You want the rear great loaded and unloaded parabolics or hybrid versions like saxs in the rear are the go .
I have a few photos of myn in the link below 2 different sets of tyres there all with EFS 2" all round.
jspbp4
Phs,
Thanks for the reply so do you think that the 2" lift will be sufficient i not a hard core driver just out to have a little fun and drive some out there tracks.
phs
Tyre clearance and on road stability is fine off road flex is great . Can't say much about other brands but the EFS heavy duty 2" kit is good .
for std to medium 4wding I'd think it will be fine .
And probably suitable if your a weekend 4wder and mainly work or road use
I think I will regret it a little when i lift it more it will probably perform on road a little worse and struggle to get into car parks as I sort of just get into 2.1m ones now well techniquely 2.05 with some fuel but they say 2.1 if there on Ramps you still hit the sign . but I won't know till this suspension travels at least another 20k
I came from a SWB 70 so you can see why I think it needs minimum 3" lift. As the wheel base is long + I have a 2.4 m tray .
Just looking at it in my eyes seems a 3 " would look the part for clearance .
So for me next time around ill give the 3" EFS lift kit a go I guess it will settle where the 2" lift first was .
