Kaielliceflint
Hi guys,
I've owned my Cruiser for 9months now and never had any problems, however in the past few months I've had a problem with the car 'hiccuping'. It doesn't do it all the time and doesn't seem to have anything thats reoccurring to cause the problem. When the car is under load or even when idling down hill it happens, in sync with a click of a relay? inside the dash. The car doesn't lose power, and I can almost simulate the problem by switching the ignition off and on. However the problem is more abrupt than what I can simulate. I've spoken to several mechanics and they believe the hiccuping is from the actuater and pushrod shutting off the fuel to the fuel pump or something to do with the edic motor? I find it hard to believe it's something mechanical because it's triggered by the clicking sound. It's an intermittent problem, so whenever I've taken it to the mechanic it doesn't happen, but when it has happened recently I've changed the front drive control relay to see if it's that, but it still kept happening. When it does happen the hiccuping reoccurs roughly every 20 seconds and if I keep driving it sometimes gets worse. I've read up in other forums that it's somewhat a regular problem that happens to 60seres in particular, but in other forums the problem seems to be slightly different to my own. Does anyone have any thoughts on what could be causing the problem??
Cheers!
Cheers!
