Choook
See if I can get it right this time.
I’m selling my 2000 Land Rover Discovery II TD5 Auto 357,000km
$6000 ONO
The good:
APT slider side steps
APT steering guard
APT fuel tank guard
APT spare tyre carrier
King +50mm heavy duty springs with Proride shocks and steering damper
Xrox bar with 12000lb Ridge Rider winch, light bar, led spots and led fog lights
Dual battery in rear with 2 x socket, 2 x USB plus volt and amp meter
235/85/16 AT tyres 50-60% remaining
Alloy Ironman roof rack on 9” steel legs with 2 x 3m awning
1kg fire extinguisher
Provent style catch can
Oricom 80 ch UHF
Custom install additional SAAS gauges, Boost, Water, EGT and Trans temp
CDL reinstated with D2a linkage and SLABS ECU (no cut wires or amigos)
Greaseable front drive shaft
Regularly serviced with service history (provided) from original owner and myself (2nd owner)
Tow bar
Safari snorkel
QLD rego to August 2020
The bad:
It leaks a little, It’s a Land Rover
Both rear doors and tail gate need latches replaced
Could probably use new engine mounts
Small hole in driver’s seat under canvas seat covers
This vehicle is in quite good condition given its age and is used as a daily. Recently replaced injector seals, harness (sealed) and cover gasket as well as FPR and CPS. There is a couple of spots of clear coat coming off driver door and there is an almost unnoticeable scar on the front to the left fender (see pictures). This would make an excellent weekender or bush toy and I will include a few spare parts I have as well as a NNN ECU (not installed) for you to install and map any way you wish.
$6000 ONO
The good:
APT steering guard
APT fuel tank guard
Oricom 80 ch UHF
Tow bar
Safari snorkel
The bad:
