If you put it on the roof, which is my preference, you can adjust it back from the screen until the roof is blocking the light down onto the bonnet which does away with the bonnet glare problem. If you mount it to far forward you will get bonnet glare like croozza said, and it will be even worse with a white bonnet.
Personally id put it on the roof, as any lighting above your eye level will cast light deeper into holes etc and will do away with most of the shadows you get if the light is below eye level (if that makes sense to you)
