Kumho Mud Terrain KL71?
JP25
I'm looking at these for my next tyres.
Anyone got anything good or bad to say about them?
chris_stoffa
As a daily driver or as a play tyre ?
As a daily driver, probably NO, they squirm and wander a bit at 90-100kph requiring constant correction, it tends to be tiring on a long trip. They also squirm under heavy braking which is to be expected a little anyway. Even so when used on the road they aren't hopeless either, they are an acceptable road tyre unless pushed to their limits which quickly become apparent in the wet or hard driving - I tend to drive harder than most.
They aren't terribly noisy , in comparison to others that I have ridden in they are actually reasonably quiet. But seeing that M/T's tend to get noisier as they wear down I can't say how they willl go with 30+K on them. I have done approx 15-17K on them so far - I dont expect more than 35K from them as play tyres - they get well used :D
The A/T 78's are a much better choice as a road tyre - Im nearing 90K on my set of 78's and expect another 25-30 - I have six which I rotate on the Camper as well.
As a play tyre the 71's are very capable, they clear well , except in the really heavy clays, they stand up to the rocky tracks of the high country and Victorias shaley rocky tracks very well without chipping and they do very well in the soft sand of the desert areas of Vic and SA. - they actually "pump" the soft dry sand like water - interesting to watch :D They are often dropped to 18-20 psi, bag out well and so far I don't have too many problems keeping with the Patrols Prados and other similarly equipped vehicles
I have done approx 8 K on them purely off road so I've had a reasonable time to get a idea of them
They are very directional which makes full rotation impossible and the spare has to be either a MT and risk the rotation issue or a spare A/T is carried.
If you do opt to buy them note that the 31&33 10.5 x 15's are S109 load rated and are technically illegal on your vehicle as they are 6 ply side walls.
The 265's etc are S112 load rated with high ply rating
I have cut a tyre wall to the cords on a sharp rock ( I think) but it hasn't actually cut any cords themselves.
Also with the 71's I had two go out of round and lift tread from the belts in the first 500kms - once picked up by my tyre fitter , the tyres started to vibrate and wouldn't balance, KMART and KUMHO replaced them on the spot and I have had no further issues with the replacement set - they replaced the set
Would I buy them again -- Sure, So long as the price is right again - Yes as a play tyre , but not as a daily driver tyre . I 'd much rather my 78's :D
JP25
Wow. Thanks for the comprehensive report Chris. They will predominantly be a play tyre, but on a daily driver that only does 15k per year. My concern, due to how blocky they look, was the noise factor. I realize they are mud tyres, but there's noisy and then there's really noisy. Given the significantly cheaper price than the big boys, I may give them a shot. Thanks.
CatchinJack
Had them on my old pajero, best tyre offroad but in the wet on the black top they were slippery, if going under a heavy fourby they'd behave better.
I'm looking at getting them again for my patrol as i hate my hankooks.
03GV
I know a kumho dealer that would not recommend them to people he knew because he didn't want them coming back to him and complaining. They wear very quick, even under a light car like suzuki.
As he would say also, there is a reason they're cheap.
chris_stoffa
Compared to the more well known brands there is a slim margin in them which could be his reluctance to recommend them ;)
03hilux
Send Wang a PM. He runs them on his Rocky. I did a trip with him a few months ago, and he didnt seem to have any dramas. Plenty of grip on near vertical surfaces.
Wang
I like them. I was surprised how quite they are on the road. And compared to the old kumho M/T they are a lot better and grip better which was an issue with a light truck with plenty of horsepower:)
off road i cant fault them. But they are a play tyre on a play truck never really done heaps of touring miles or sand work.
i think chris-stoffa has provided some pretty solid info that should be taken on board.
Only bad point is they wear quick which others mentioned.
JP25
Guess you get what you pay for. I'm running federals at the moment which were cheaper but wear quickly. I'm finding it hard to dish out $400 a corner for the big brands.
chris_stoffa
One other thing that I forgot but mentioned elsewhere - drive them into standing water on the road way and they WILL pull you into it - must be the directional thing.
Its quite pronounced so slow down before you hit it :D
I have done 100,000 kms on my KL71s on my GUIv, I have 6 also and rotate through.
I have found them bloody Great on Bitumen, wet or dry, amazing in the Snow in thick heavy Mud they performed beyond expectations (I run Simex ET2 on my GQ so know what mud does) and are fantastic in the sand at 15psi.
They were surprisingly quiet on the road for the first half of their wear. And have gotten pretty noisy now.
Rotation sux! For this reason alone I won't buy them again. To rotate them properly and limit the scalloping (quite a bit) you need to flip the tyres on the rims. I have paid to do this twice over the life of the tyres to allow the right hand side tyres to be run on the left side. I should have done it a couple more times but it cost $50 to $80 each time. Add that to the initial cheap price and it brings them up to a KM2 or MTZ and will probably go to one of those.
I have been up through the centre towing a camper during the floods of 2012 and they blew me away in the mud around Mt Dare! Crazy Good. I crossed the Madigan Line of the Northern Simpson and they ate it up.
The Victorian High Country was the perfect place for the kL 71s. Worked great.
I rate them very highly. Solid on road performance and feedback. For rotation alone I will not buy them again though.
285/75r16 on GUIV Touring and Daily.
chris_stoffa
Mudrunner, what pressure did you run in them on bitumen?
Haven't experienced any scalloping yet on the Bravo at 30-32psi when roadrunning
chris_stoffa
I'm only 2200kg fueled and with average weekend camping / shooting gear and running 30-32 so it might just be a weight / different vehicle thing.
When I tow the camper I only go to 36 in the rears
You are solid axle , correct ?
CatchinJack
I got 60,000km out of mine, ran them between 34-36psi and they used as a daily also. Place in Sydney does them supply only for a 285/75/16 at around $220 a corner, supply only.
