Jockey wheel install on oversize trailer
deepop
So I have an enormous box trailer (at least I didn't say deck in a Kiwi accent) and felt the need to put a jockey wheel on it (don't ask why because I don't really know - yes I do, it was there).
Due to the fact that it has 2 (obviously over-engineered) 70mm right angle section lengths of steel as a draw bar I stupidly asked the question on this forum as to where the best place would be on said right angle section to drill two holes for the jockey wheel bracket. http://www.4x4earth.com.au/forum/ot...drilling-hole-length-right-angle-steel-3.html
In amongst the obviously very humorous and clever replies I received, someone actually gave me some sensible information - drill them in the middle numbnuts (poetic license taken).
Following is a number of photo's (to make the whole thread worthwhile) of this involved build-up.
In this photo please note the existing effort to keep rainwater from pooling in the front (also take note of flower petals spread artfully around trailer to dress up this mutton as lamb).
Photo 2 shows high end expensive jockey wheel clamped in position to mark holes
Photo 3 shows hole positions marked and centre-punched (note spiderwebs installed for scary effect).
Photo 4 showing pilot holes drilled and strange blue wig type object hanging on camper trailer in background.
Photo 5 showing completed project in situ (as it stands - so to speak).
And lastly photo 6 showing said trailer absolutely dwarfing the 'cruiser and giving some scale to the project.
Thank you for taking this journey with me and for the earlier helpful comments I again thank you! And for the earlier non-helpful comments I will thank those people personally.
80lover96gxl
The scale of the project undertake was enourmus and I can understand why advice was saught.
The next project undertaken should be the duramax conversion to haul that bad boy around.
Thanks for sharing and a job well done.
cheers,
Brian.
Traveller
I do like how you implanted a bit of the strange blue wig type thing into the vee of the enormous trailer too. Well done on an impressive bit of engineering mate!!!
Grumpy
A huge effort there was worksafe notified about the enormous task you had in front of you and did you do a take 5 or at the very least a JSA so as you could complete the mammoth task in a safe manner.
yobboford
I'm not one to normally be critical at all, especially after seeing the complexity of the task undertaken, but I feel it my duty to point something out: It seems in photo three (3) you can quite clearly make out the "Spiders Web" bracing used to secure the spare wheel to the trailers draw bar but unfortunately it looks to my expert eye to be "NON-STRUCTUAL" spiders web, it is these sort of short cuts and dodgy-ness that can lead to very serious situations arising.
I would suggest either replacing the spiders web with structual spiders web or blurring the photo so the current web cant be seen, as we all know if you cant see it there is no longer a problem.
Hope I have been of some assistance, have a nice day.
P.S. Great work on the jockey wheel, sometimes those hours of planning and toiling away can seem for nought but in this case the end result must make it all feel more than worthwhile.
deepop
Thanks all for the kind words.
duramax conversion hey? might have to consider it thinking about the load I might be hauling.
It could be Big Rwig's trailer except it's not that crayon blue colour. (Except in some places).
Worksafe came in and turned right around again - mumbling something about the job being too big for them to be able to work out.
Thanks Yobboford, now worksafe will be back to check on the quality of my web work - they now have a target handed to them on a platter. Where can i get cheap structural web from?
tankbloke
Well done Darren....Tankblokes not easily impressed, but I don't mind saying, I would be so proud if I had the Balls to attempt such a Herculean undertaking.Keep up the good work.
BEK
Now Deepop the job isn't over until you make the wheel match with that very adorable rust affect you have created on the trailer.
Must have cost a fortune to get someone to mix that textured colour for you
Where did you get that trailer drainer I need one of those
Keep up the good work and I expect you will be on CH 74 with your own DIY show ....
BUSHNUT
I really think you have to continue the paint scheme on the tow vehicle , it really needs that rustic look !
Grumpy
Now in order to honor your mammoth rebuild I would suggest a good sandblast, no maybe not, how about a lazy coat of paint to allow the new special webbing something to adhere to.
LowLux
Lucky you got the right advice on this goliath project...it could have turned out quite nasty if not correctly engineered and properly project managed. Was it difficult putting the CAD drawings together and from whom did you seek advice on the process undertaken to maintain structural intregrity of the A frame?
deepop
Which small portion of it should I repaint? - and don't forget it needs to be in a different colour.
Thanks Lowlux - amongst my many actual talents (as opposed to what I think I'm good at) is the ability to CAD draw so the planning phase was all mine. Advice from all the talented, skilled and professional (?) members on this forum gave me the details on maintaining the integrity of the over-engineered A-frame.
muc the truck
how about treating your trailer to a coat of fishoil then let it harden in the sun and paint some enamel over it . It might last as long as the dolley wheel then
