Jimbob 2.0 mini adventure machine for two
#1
It starts again , this time a little different , I'm building another mini tourer.
I know everyone is going to say it can't be down, jimnys are way to small .. well I beg to differ ... back packers travel with only a back pack , light think smart light weight with the bare essentials.
The vehicle
2004 jlx suzuki jimny
Engine : M13a
Options : ps,ac,central locking , power windows
The plan :
Build a capable two person offroader with a 5x4 aluminium trailer.
Goodies coming :
M16aa with a rotax sc suercharger .
Add engineering bash gaurds
Sliders
Leopard barwork fr/rear
Swing away with jerrys and fridge mount
6000ld light weight utv winch
30x9.5 15 bfg TA
Hp electric lockers
Cargo cage
Dual batterys
Sierra transfer 17% gearing drop
Procomp 3" kit
More once this is done
#5
Battery system
The 3rd mod for the weekend was fitting a optima yellow top and a redarc smart monitor for both batterys.
I had a hilux dual battery tray laying around so i decided to use this , it only needed a new hole drilled and a bracked made for the left hand side underneath
#6
Dash mods
After fitting the batterys I decided I needed to monitor them so I brought myself a raceface battery monitor gauge from ebay
While I was at it I purchased a oil pressure gauge and a pod to mount them in.
I Cut a hole in the dash and fitted the gauge pod using 3m glue to glue it in and proceeded to smooth everything off .
#7
Ipad in a jimny dash :
I am one of those guys that hates plastic suckers all over the windscreen and I use a ipad with mudmap for navigation purposes, my samsung with mm tracker and a back up paper map .
I decided to fit a ipad mini 4g to the dash for these duties aswell as spotify and what ever other app we will need.
so at this point I undid all the previous work I had done undercoating the dash , i cut out the heater vents and main control bezel .
The plan is to use a soundmanCA opad mini slider kit for ease of removel.
#15
2004 suzuki Jimny custom roof console .
Finally finished fitting my roof console to the jimny , I used 4x angle brackets , tapped the two rear holes in the roof out to m10 and picked the front mounting location off the interior light position while i was there i adapted a rear led light to the interior light .
#16
jimny ipad dash update :
Fitting the ipad had been a pretty simple process on the 98 - 2004 , here is a shot of the final filler and sand before i undercoat
so at this point I undid all the previous work I had done undercoating the dash , i cut out the heater vents and main control bezel . View attachment 57279 View attachment 57280
The plan is to use a soundmanCA opad mini slider kit for ease of removel. View attachment 57281 View attachment 57282 View attachment 57283
