Jeep TJ Wrangler (Extreme Sport) 2004
Jet Dingo
Jeep TJ Wrangler (Extreme Sport), 2004
Good Points
Well its a Jeep :p
6 Cylinder (in-line) Engine (I find it grunty enough to climb anything I throw at it)
Short Wheel Base
Solid Construction (Doesn't Fall Apart)
Decent Stock Suspension
Decent 4x4 (Transfer Case)
Quality Electrical System Back-Bone (easy to expand on)
Massive range of aftermarket parts available
Soft Top / Hard Top
Quarter Doors
Plenty of storage space (when you fold the rear seats down)
Bad Points
Bash plate sits way to low, ends up collecting sand at the beach & rocks on the trails. (cant be removed, as it supports the gear box)
High Maintenance (But hey, you know that when you buy one)
Parts Cost A Fortune (But hey, you also know that when you buy one)
Shocking Fuel Economy (Wost mileage I've ever had with a 4x4)
Next to no storage when in 4 seater mode
Engaging 4x4 can be a challenge if your not right on the money when you pull on the engage lever (its all got to line up)
Speedo is off by about 10k's even on stock tires
What mods have you done?
LIGHTING
ML240XQ - 16,000 lumen LED driving light
ML300X - 20,000 lumen overhead LED driving light
ML24X - 1,600 lumen LED reverse light
ML15 - LED Side Work Light
ML18 - LED Internal Work Light (Storage Area)
ML25 (Old) - LED Winching Lights
ML48X (x2) Forward 3,200 Lumen LED Driving Lights
Elevated Tail Lights / Vehicle Mine Lights
52" Halogen / LED Hybrid Warning Lightbar
x10 Misc. LED Warning Lights
x4 Side Clearance Lights
x5 Roof Clearance Lights
OFF ROAD ACCESSORIES
Rugged Ridge BullBar / Grill Guard
Custom Jerry Can Holder (Spare Tire Fitted)
Recovery Points Front & Rear
Suspension Raise
Body Lift
New 33's
New Flares
Winch
Side Steps
Why did you buy this vehicle?
Its a Jeep :p
How often do you go offroad?
As Offen As Possible (2-3 times a month)
Not Sure
Jet Dingo
Jeep_jk112
That sure is a beast of a tj, with a stackload of led lights!!!
A tip with changing from high to low, it is recomened that you are rolling (no acceleration) between 3-5 k's so that the teeth line up easier.
i was having the same difficulties with my transfer case lever in the jk, then i actually read the user manual and it states 3-5 k's to help the teeth mesh smoothly.
That was the jk user manual, but i think the same deal would go for the tj???
Jet Dingo
Cheers Mate,
Yeah your right about the T/C, I found it works well if I keep rolling forward when I pull on the engage lever, keeps it nice an smooth, only every now and then I'll get a bit of a rough one.
frosty
You sell lights??
That explains how you drive around at night,,,,,,,,,
Seeing as your scared of the dark!!
Jet Dingo
CRAP!! Your scared off he dark!!!!!!!!!!!!!! Holy SHYTE!!!!!!!!
We're putting out close to 45,000 Lumen when we light her all up. I figure their ain't a ghost on the planet we cant burn up with this rig... yay for daytime driving at night :D
:D
Big Rig
I've seen them in action Frosty. They do burn the bitumen and whatever is in front of you.
