Jackaroo/Fuel Filter
Lost 2
Hello all,
I hope some one can help me?:(
I just did a full service on the car today,this time i changed the fuel filter.First time i have done it.Changed old for new and replaced.Problem is now the car will not start.Guessing air in the fuel lines.Would anyone have a clue as to how to fix the problem.Need to get rid of air and fuel back to the motor.Desperate:confused:
Lost 2.
0
001525
Guest
Hello all,
I just did a full service on the car today,this time i changed the fuel filter.First time i have done it.Changed old for new and replaced.Problem is now the car will not start. Guessing air in the fuel lines.Would anyone have a clue as to how to fix the problem.Need to get rid of air and fuel back to the motor.Desperate:confused:
Lost 2.
I've got a 95 Jackaroo and I've never heard of this problem before. There could be a number of reasons why the car won't start. I'm not a qualified mechanic but it might be one of those quirky things that happens that when you change something on a car and another component dies but not as a direct result of anything that's been replaced.
I'm on a long shot here but there might be a hand pump somewhere along the fuel line in the engine bay which is used specifically for removing air in the fuel line and pumping fuel into the injectors. It might also be the fuel pump or like I said any number of things. I'm not with my car at the moment so I can't really help you at the moment.
You might also try the following link:
Jackaroo, Rodeo and Frontera Owners @ Australia4WD
If you're a member of a motoring body which has roadside assist, I suggest you give them a call if all else fails.
Lost 2
Hello,and thank you for your feed back.
Maybe time to give the RACV a call.I am sure its something simple.I feel the lines need to be bleed to get fuel back to the engine.Shall keep you posted.On the out come.
Lost 2.
0
001525
Guest
Lost 2.
Good luck with it. I'm sorry I couldn't help but it'll be interesting to see what the problem is. As I said, I've never heard of air getting into the fuel line as a result of a filter change. I've never had any problems after changing the filter which made me think it might be something else.
Lost 2
Hello again,
As i had to remove the filter from its mount.There was a serious air leak created in the fuel lines.I had no option but to put the canister in a vice to remove it.The last person that changed it made sure it would not move.Any how the problem was resolved tonight.Ended up calling the RACV.After about an hour we sorted things out.An air hose down the fuel inlet to get some feed and at the same time pumping on the Filter disc at the top.The good thing about this is i am more the wiser.Just all part of growing up and getting older.
Lost 2.
0
001525
Guest
Hello again,
Lost 2.
Glad it all worked out and happy motoring.
Lost 2
Jack/Fuel Filter
Hi,
Thanks for the feed back,Every little bit helps.
After the event and much panic.(WHAT DO I DO)
As it was the first time i have done a fuel filter and as an after thought i should have filled the new one with some new fuel,before replacement.Then primed till i got a steady squirt of fuel through the bleeder.Re the bad air lock.
Thanks again for the input,just hope my experience helps someone else.
Regards
Lost 2
bt50boy
hey lost i had an old rodeo and had a problem pretty much the same. even when i did get it going again it was not quite right. so under i went and found a second filter about 200mm from the tank conection point caked in mud, dirt, sand and god knows what ( hence why i didnt see it first or second and third look)
so have another look again just to make sure you dont have a double up.
Lost 2
Hi ,thank you for the info.
This weekends project is,to change the glow plugs.Just hope one does not snap upon removal!Then give the old turbo a clean up i hope?
Amongst the cut and bruisers,I will check out the thing you mentioned just out of curiosity.Hopefully back on the tracks.SOON.Just making sure the car is right.Before the next day or trip out.
All the best
Lost 2
