Isuzu MU-X Oil catch can
wardss
G'day , any one out there installed a catch can on 2012+ D-max or MU-X? Not much room and Ol mate Provent is too big to squeeze in both height and width. Would love to get some links , photos etc... I have seen a mock up provent 100 on ebay but not to keen...o_O
Shauno
Cokedaddy216
HPD sits on right hand side , bracket included , uses factory bolt holes 2016 model anyhow , if there the same .
Jaye
Have you checked with Western Filters? They supply a kit for most models, be supprised if they didn't.
red hilux
Why aren’t you keen on the provent 100?
I’ve fitted on to mine as I have a space problem also. No problems so far
wardss
so what would you suggest? I was looking at the SAAS autobarn models baffled and gauze filter???
red hilux
Bugger.
I bought that for my old surf like 5 years ago. Never fitted it.
Mine has the stainless steel filter in it. So hopefully I can get away with it
Aaron Schubert
Really
It looks like it flows fleely using the mouth a meter test.
I used that as I can’t find room for anything bigger
The 200's are a huge unit. I'm sure they work it out as a worst case scenario - I bet every motor has a different amount of air flow. You might be right. I thought they all ran filters, not stainless? Is it a genuine unit?
Aaron
wardss
Finally sorted it out...just grabbed a SAAS baffled catch can and fits almost like factory..couple of elbows for pipe and one 6mm drain barb @ drain port ..
fairly well made item 3 x baffles and filter media servicable,,,can add air vent filter if require..but hey not racing a quarter mile in it:);) $99 @ Autobarn on sale.. If it fails its only 1 tonne Ive wasted, I have heard good reports on these if you are not a hoon and thrash the bones out of your vehicle....
