Isuzu MU '94 - 4jb1s motor
9eorg
Gday peeps,
Signed up to forums awhile ago peeps but been inactive as was looking to purchase a Hilux mid '90s. However finally found a 4b which I should score end of this week, alil different to what I was aiming for however.
Scoring a Isuzu MU '94 2.8ltr diesel turbo manual. 4jb1s holden rodeo motor.
Anyone have any dealing with this motor? Pro's or Con's ? .. new to the diesel thing so unsure if this a good motor, specially as I've had nothing to do with holdens either.
With luck she will be a good offroad beast to learn with the short wheel base. Only draw back I find with her is the pull hand break near the dash :-\ .. time will tell :)
Will post pictures as soon as I get her home and she's okay from the inspection. ;)
Tappet
It's a great motor. The Cons-Slow and noisy. The Pro's- will go for over 500,000K easy. so long as you stick to the usual servicing. Filters and oil... Doesn't hurt to set the valve clearances on these things now and again to.
9eorg
Nice thanks Tappet .. I'll have a looksee on forums here if there is a how to with valve clearances. If to technical I'll have to find a good diesel mechanic in Southside Brissy somewhere. Any suggestions for a good diesel mechanic ? :)
9eorg
Okay just double check with old mate selling car its actually a:
1991 Isuzu MU - 4JB1 motor .. thoughts on this motor plz ? ;)
sorry for newbie questions just always alil nervous buying 4b's as not to get a lemon when unfamiliar with type of motors :D
Thanks!
BOUNCY HJ61
Greetings 9eorg,
Mate, They Are a Top Engine. Under Powered = Low Stress = Last Forever (almost)
I Have A 4JB1T, The Turbo Version. Just Do Regular Oil And Filter Changes, Every 5000km.
And If Getting A Little Noisy, Inlet And Exhaust Clearances Are 40 Thou.
Suspension Kits Are Sold For The MU, But If You Want Something a Little Extra - Check Out "Calmini Suspension".
These Engines Are In Isuzu Trucks And Also Generators, Which Sit All Day At High Rev's 2500-3000 rpm, Which Is Where They Perform Best. Gutless Low Down But Economical. You Have To Give It To Em If Sand Driving.
It's A Very Different Car To A Hilux! Don't Assume They're Similar.
Enjoy,
Cheers Michael
JC807
i thought the only truely Holden engines were the old straight 6s, the starfire and the pre-GenIII v8s.
correct me if i'm wrong, but never thought they did anything diesel
9eorg
Okay nice thanks bouncy makes me feel alil more at ease then :) .. looks like I'll have to learn how to do beach driving again in her then.
@ JC807 unsure mate, thats just what I was told by bloke selling it. Why I wanted to check to make sure I'm not buying a dodgy MU as he said he swapped it for a holden rodeo engine as the original in it packed it in.
Thanks so so much for the help peeps much appreicated :)
muc the truck
unlike the gear driven rodeo version the mu has a timing belt for the pump. so I would replace it.
the gasket under the timing cover is different to Holden rodeo and if coolant is not kept in top order it leaks into the sump. the gasket is hard to come by I had to make it.
apart from a silly upsidedown oil filter the car itself is bullet proof. servicing is not expensive. clutch is about 380. drivers side power window module wear out but what do you expect from 20 pluss years. there a awesome rig. I got rid of mine because there was no room for kids and lugage
9eorg
Can you clarify on replacement of the belt please Muc ? As in replace the belt with a different one I take it?
I'll make sure to check for any leaks from the timing cover as to minimize any issues. I'll give her a good overhaul once in my hands.
Thanks Muc for tips ! ;)
muc the truck
if its a rodeo motor wont it be gear driven . only the mu 4jb1t has a belt for the timing . the model mu you have should have a 4jg2 in it .
MatOZ
Dive shaft seals on the injector pump do go hard after awhile. Causing hard starting and running rough due to air passing the seal.
stardog
I think he means it has a 4jb1t 2.8 engine out of a tf rodeo in it.
Which are gear driven not belt I am installing the same into my 94 MU tomorrow but I am using the flywheel and clutch out of my 3.1 and the oil filter assembly as well because I have a 3" exhaust system and intercooler on it I cracked the head and had a heap of blow by because the rings are gone this was a cheaper way to go than get the 3.1 reconditioned. don't know if I will fit the 3.1 turbo on it yet see how it goes with the 2.8 turbo first.
If it is a 94 should have 4.3 diffs LSD in the back and fit a lokka in the front diff and they are a top little wagon mine has got where I want to go with no problems out on the tracks I pulled the back seats out and fitted storage unit and a 50 lt fridge in there.
stardog
MatOZ
stardog
That's right I was talking about the 2.8Liter Isuzu engine. There are ERG 4JB1 engines in the MU. Pump seal does wear the drive shaft over time with the Zexel pumps they use. Gear or belt drive has nothing to do with the VE pump seal.
muc the truck
I thought mu had 4.5 diffs. and in Sydney I know some one that had his 3.1 rebuilt fitted for 4 grand . new pistons, rings , cylinder liners , reco head. cleaned injectors and used his pump
stardog
Not all of them Muc 90-93 2.8 td had 4.5. 94 onwards with 3.1 had 4.3 diffs.
How long ago was that for 4k a lot of places wouldn't touch the 3.1 engine a rebuild kit from roodogs $ 2700 found 1 other kit $ 1800 and new head and gaskets $780 delivered. then pulling engine out and rebuilder labor costs on top it was cheaper with me getting the 2.8 out of a rodeo only have to change engine mounts over.
But because I want to change oil filter over to the 3.1 and put the intercooler on it a little bit more work.
Stardog
muc the truck
the 3.1 was rebuilt about 2 months ago , I will find out the workshops name
had 2 motors tochoose from to rebuild. either a 2.8 or the 3.1 , both were quoted the same price $4000 fitted . he is going to rebuild the 2.8 him self with a kit from ebay for 600 bucks
2.8 kit
EOK0035 Brand New Isuzu 4JB1T 4JB1 Turbo Charger Type Engine Rebuild Kit | eBay
3.1 kit
New Isuzu 4JG2 Engine Rebuild Kit TCM Forklift Truck | eBay
Just wondering if the 3.1 had a bigger radiator in it than the 2.8 . any ideas
stardog
I'm not sure about the radiators the 1 I have is the same as the v6 petrol rodeos I have a alloy radiator in the shed I put in a while back didn't make any difference in temperatures.
Muc if you could find out the workshop that done the job that would great help to me.
muc the truck
Thanks , I just sent him an email should be able to tell you this week end who built his engine.
