Is this a safe recovery point?
ferozious
Ive been on a few 4x4 trips now, but I've only ever needed to be towed out twice :cool:, and they were using the front rate anchor point.
For the rear, I don't have any rate recovery hooks on the chassis. :eek:
Ive got a tow bar though :D(four tensile bolts mounting the neck to the chassis), and since i don't use it much :eek: , i took the tow ball out :), and put a rated bow shackle through the hole. :eek:
Is this a safe recovery point or should I pay to get one of those hooks that you mount yourself? :confused:
(i only have a relativlely light daihatsu feroza, but thats not to say i wont ever get bogged up to the axle in mud/sand etc :eek: - or have to rescue a cruiser or patrol :p )
Also, does anyone know whether or not you're allowed to drive around on public roads with shackles attatched to the car :confused:
kiwijaz
rather than buying recovery hooks for the back and you have a haymen reese style tow bar you can buy a recovery incert for the towbar. you can pick them up from 4x4 shops or supercheap they usually come with a rated shackel (around the $50 mark). As to driving round with shackels on you vehical as far as i know there is no law against it but they get get stolen.
K Rudd
This is the rear recovery point we use, works a treat.
Big Rig
AND as Jaz forgot, they get jammed in the mud and are hard to get off when you need recovering. Hey Jaz :p
ferozious
thanks for the advice,
only problem is that i dont have a haymen reece style towbar, (what about your feroza poolman?), so might just get a hook one anyway, since theyre only around $20-$30.
K Rudd
Problam is when you bend the pin, and YES, I have seen one bend and they do, you need an Oxy or grinder to cut it out.
Material Tensile-Relation Yield-Relation
Wrought Steel & alloy steel Ssu = Approx 0,75 x Su Ssyp = Approx 0,58 x Syp
Ductile Iron Ssu = Approx 0,90 x Su Ssyp = Approx 0,75 x Syp
Malleable iron -Pearlitic Ssu = Approx 1,0 x Su -
Wrought iron Ssu = Approx 0,83 x Su -
Cast Iron Ssu = Approx 1,3 x Su -
Copper/ & alloys (See Note below) Ssu = Approx 0,65 x Su -
Aluminium/ & alloys Ssu = Approx 0,65 xSu Ssyp = Approx 0,55 x Syp
Wow,you must pulling out locomotives !
Grey Ghost
:confused:Su Syp Ssyp Ssu xSu :confused::confused::confused: um can I get that in everyday speak please coz it means squat at the moment..
frosty
5ml of tensile area. Whatever ?? Is that you Bart Simpson ???
5 Millilitres of tensile area??????
Whats that got to do with puting a soft skinny strap around a 10 mm pin and pulling heavy stuff with it?? It's gunna bend.
jack48
Hey guys, why not put the tow hitch in & a heavy D shakle on the draw bar, at least the 10ml shaft won't bend then, all you've got is a longer vehicle to get hooked up on steep inclines etc.
