Rangie85
Hi All,
I have the opportunity to get a lift on my 85 Range Rover Classic. The current stock front off side shock is sagging so I might as well get them all done, and I thought I might as well get a lift at the same time. My mechanic tells me that 2" is the maximum lift you can get without having to adjust a whole load of other bits and pieces (has advised changing the shocks too) and so it then starts getting really expensive.
So my question is; is it worth it? How much of a difference do you really get with a 2"? Other than cosmetic, which would be slight, and the ability to put (presumably) bigger wheels on (I have 30" on there at the moment, I think, slightly larger than stock).
Any guidance would be welcomed.
Cheers in advance
Cheers in advance
