Ironman Compressors
Luke
Im in the market for a air compressor, OL have the Ironman Flo Max, 72lt per min, 150 PSI Max pressure, 3yr warranty for $139 down from $170
Any one have one or got any thing bad to say about the Ironman Compressors.
Cheers,
Luke
Nice, have you mounted it or kept it mobile?
I Think it is best value from what I have seen around a few of the 4x4 shops atm, for only $139, I dont think I can walk past it.
Ripco and supercrap have the same chInese stuff,
Ripco have 150ltr a minute one on sale recently, maybe now for $149
I have the ripco 72 lt/min was $99 on special.
One or the other regularly has them on special.
puff0417
Prob going to keep it mobile I would have liked to have got mine for that price
David4B4
I also have the Ironman. Used it twice. Worked fine, however its never quick enough. Great value for money.
kyleb
I had the Projecta version of the 150l/min pump. It lasted a while, but I cooked it one day pumping my 33"s back up and then 2 of my mates 31"s without giving it a break to cool down in between. The motor failed the next time I went to use it, when I pulled it apart I found that the wire attached to the brushes had melted and become very brittle. I'm pretty sure I exceeded the duty cycle and it built up way too much heat.
If you let the compressor have a break between each tyre it will certainly help. Also, if you start a compressor before you hook it to the tyre it is much better for the compressor as it does not need to start up under load.
Luke
Well got the missues to pick up some gear for me the other day while I was away for work, got even better deal on the air compressor, ended up getting it for $118, :D
Also got an ironman HiLift Jack for $90 and 4 new ironman shocks for $100 each :D
Yet to test the compressor, tho i do know the spare needs some air, should be on the cards tomorrow morning to test out
Muzza87
my mate has got a iron man one and the hose pops out off the fitting when it gets hot we put a solid line then a connecter on it works good now
hope that helps
