I dropped into Dick Smiths and grabbed a 150W $60-$70 and a 300W $100-$110.
i use the 150w every week and works great, my farther uses the 300w and also hasn't had any problems.
G'day.
Hate to say it but get ready for the pop-and-stink!! been through three of those, and i assure you, not from overloading. As the OP said, pure sine is the way to go, and in my experience cheap inverter = sadness and disapointment...
Yeah, i'm looking at 600w only because we will run a laptop from it. I know 300w will do this too but i always like to go a bit bigger, ie. stronger so i know it will last rather than get one that JUST does the job.
After I resoved the above equation about inverters and sadness, I got a 12v in-car universal power supply for laptop (search ebay) for much less than a dick smith inverter and havent looked back...
Running an inverter to power a laptop means you are sucking watts out of the battery to get 240v, only to have the laptop power supply scale it back to 12v/19v whatever. Its like you want a glass of water so you drain a jug out of the tank, fill your glass from the jug, then tip the rest of the jug out in the sand... its a very very inefficient way to run a low voltage, low watt appliance.
