Intermittent Mitsubishi triton 2wd flashing light
Frank_triton
Hi guys,
I'm hoping someone with similar problem can help me diagnose my car problem and help a quick find to the solution.
For a while now my 4wd light has been flashing (engaging 2wd) when I haven't engaged 4wd on my Mitsubishi triton ML GLX-R. The light would flash some times on start up and some times not until a few weeks ago it was not flashing the I heard a whining noise which turned to a grinding noise as I slowed down then a clunk and the light started flashing and no more noise.
I took it to mechanic who helpfull tried less expense methods by connecting a computer to the car and running a test and initially the computer showed the left front wheel sensor was faulty and giving a false reading on speed. But when he seeked a second opinion from his colleague who's friend had the same problem said it was one of the two solenoids in the gear box.
They got a solenoid from Mitsubishi and changed one but the same problem but as it was a call in on my break they didn't have time to swap around the solenoids to see if the other one was the fault.
Please does anyone have any idea on the fault or has had the exact problem for a solution to mine.
Thank you
MatOZ
If you have one new solenoid, try swapping it with the old one.
If that dont work check all the vacuum lines for damage as a start.
bruzzz
I’ve been having issues with the 4wd since I picked up the car yesterday from ARB for diff breather extension.
While its in 2 H the front wheel lamp keeps flashing as if it would be changing from 2H to 4 H or vice versa.
In 4 H works fine.
When trying to switch from 4 H to 4 HLc the centre differential lock lamp keeps flashing. Have the same issue when switching to 4LLc.
Flashing light means “drive mode switching in progress”. When it stops flashing and light is turned on it means it has correctly switched into the desired drive mode which will only happen in 4H.
I reckon a sensor or somethings might have been manipulated (probably accidentally) while doing the diff breathers yesterday. I need this to get sorted asap please HELP
Tink
As I said in your other post, take it back to ARB, it will be covered undr their warranty.
Tink
