thanksOnly if you need it to run a fridge etc otherwise there is no need
Slightly off topic, but same deal for your compressor.Just make sure that you keep the engine running when you are actually using the winch in a recovery. They draw a lot of current and you will soon flatten your battery.
And remember duty cycle for both.Slightly off topic, but same deal for your compressor.
Get a compressor before you get a winch.
It's normally the compressor / winch that has duty cycle concerns, as the motors in them overheat (or bearings as well).@Chatty Is running them too hard bad for the unit, the battery, or both? I run my compressor pretty hard, but I'm only using 265/75/R16 tyres. Not as much air required as some.
I just monitor it, rather than have set run/rest times. I've been out and given my winch an absolute flogging and the motor has barely got warm. I do up the RPM so it doesn't completely suck the guts out of the battery though. Working it hard with a lower voltage and it does get warmer quicker.And remember duty cycle for both.
Compressors and winches don't like being run 100% - usually work to something like 5 minutes on, 5 minutes off.
Also never had trouble with a winch getting hot in the past 30yrs it depends how you use it. Don't be in a big hurry and push it till breaking point on a single line pull then you'll flatten the battery as well. Snatch blocks make a big difference and being able to idle the engine up to help charging the battery with spotties off at night. I'm looking at Sherpa winches for my next one any one got one. I left the 22yr old Warn XD9000 on the patrol when I sold it which was still working.
Or maybe for the other reason we install dual battery systems, in case your in the middle of nowhere & your starter draws flat or fails.Only if you need it to run a fridge etc otherwise there is no need
To me thats more important than keeping the beer or milk cold![]()
I remember coming across a couple out west who had a flat battery after camping there and were sitting around waiting for their solar panel to charge up their battery so they could start the car.
Gave them a jump start but I guess they would of sorted themselves out in another 3 or 4 hours
You need to get with the times mate. Plenty of inexpensive, quality lithium jump starters that will get you going again. Small and easy to stow.Or maybe for the other reason we install dual battery systems, in case your in the middle of nowhere & your starter draws flat or fails.
That's not a long time - try it when you have 10 wheels to reinflate after a corrugated dirt road. I'm looking at around 45 minutes.My compressors in the past have had no issues running for long periods of time 20 minutes or so.
My patrol only had 4 x 285's but the main compressor I used was around 16yrs old.That's not a long time - try it when you have 10 wheels to reinflate after a corrugated dirt road. I'm looking at around 45 minutes.
