Indicator lights flashing to fast
dochol
Banned
Have just installed led tail/stop indicator lights to the rear of my tray, as the old ones hung down from the tray and were always gettin bent and lenses broken.
The flash rate has increased to a pace similiar to when there is a blown bulb, is there any way that this can be rectified and how do you do it
Joe
You will need to change the flasher can. Because the normal globes draw more power than led lights, the flasher can needs to be an led specific can to slow the indicators down to a normal speed.
LRDS2
An easy fix is to put a resistor inline before the lights. They are and easy cut and plug solution! If you change the can it may effect other operations of the electrics! I know this as I put led tail lights in my play ute and had to do the same thing!
If you bought the LEDs from a reputable store, ie not eBay, you should just be able to go back and tell them your issue and get a resistor to fix the problem!
Hope this helps!
PK Kitchens
Guess I got lucky then. I just changed mine over the LEDs as well and they just worked.
Great looking lights too :D
Good luck buddy
Pk
Put a relay unit in mine no problem back to normal speed they are out of stock at the moment LED Light Bulbs, LED Auto Light Bulbs, Marine Replacement Bulbs Australia & Worldwide click on 8 to 30 volt Automotive/Motorcycle centre of page then indicator reverse light in green writing then electronic flasher units the 2 pin unit has 2 pins plus an earth wire thats the one you need for a GQ .You can run combinations of globes or change them all to led's like I did. Plug in a trailer with halogen globes no problem only cost me $25 delivered last year. Easier than mucking around with resisters which an elec told me you need 1 for each indicator cutting and soldiering wires. Get the relay unit when their available just plug in and away you go
