I'm sure it's an idiotic question, but.....
cloughcarib
I just(today) bought a 120 Prado:D which has a long range tank in it. For the life of me I can not work out how to access this tank:(. There is only one fuel fill, so I'm assuming there is an over-flow between the tanks, but how do I switch between them????:eek:. On the fuel gauge there is a light that says "90L", I can assume this isn't referring to the amount of fuel as the actual gauge reads about 1/8 of a tank, but I don't want to run the tank dry to see if it switches over on it's own. Should(or is there normally) a manual switch to change between the tanks?
Thanks. Clough.
Big Rig
Easy solved. There are two 90 litre tanks with one filler. There is a spill over pipe in the filler neck to fill the both tanks. I'm not sure myself as to which tank empties first or if there is a transfer pump or a couple of solenoids on the fuel lines that switch between tanks BUT - when both tanks are full the gauge registers full. When the first tank is empty the gauge will run down to approximately 1/2 then it will return to the full mark then register a green 90 L. This indicated you are on your last tank.
Hope this helps....;)
Big Rig
There is no manual switch to switch between tanks. I am leaning towards the transfer pump theory though cuz i generally get about 850ks to the first tank and the gauge drops to just under 1/2. I reckon it starts transferring fuel from the auxiliary tank at 1/2 and when its empty the gauge changes over the the full mark and displays the 90 L light. This last tank I only generally get about 4 to 500 ks.
bmurray2250
The 90 series had the manual switch on the dash to select which tank was active. Having a fuel load that gives you over 1200km is great for touring.
Big Rig
OK, how about the dual batts? I was happy to find them, but didn't expect them
Not sure about the duel batteries in your model. They are not standard but a good point to note Clough: just check the charge rate. There was a real problem with the later models more specifically the D4D common rail. With all the electronics the manufacturer reduced the alternator output to below 13.4 volts. It was a real problem for me towing the camper trailer as I couldn't get enough juice to the camper batteries. All these problems were easily overcome once learned.
bmurray2250
I did some wiring in my brothers Pajero today. We installed 8mm2 cable which should be able to supply 20 amps without issues. The previous wiring was to small and all the connections are soldered. 12.6v at the battery and 12.59v at the connector back. Putting large wire through helps to stop voltage drop and burning out of the cable. I also put a relay in the circuit so the accessories could be isolated. The dual batteries, get a good dual battery isolator. This will charge both batteries correctly. Rodw did some stuff on this too
cloughcarib
Cheers bmurray. I have good knowledge of 12V systems(marine) and this car seems to be set up well. I am a huge fan of crimped, not soldered connections for heavy draw items. Although the isolator and relays are more than adequate, I will(eventually) upgrade the wire gauge(size).
carves
Oh Dear, Oh Dear, Oh Dear .....
So you have gone out and bought a little all wheel drive station wagon ????
I thought you said you wanted a 4x4 ????
..... and you were getting a Delica with lots of seats ...... :D
Definitely put your 12v sparky "know how" to use .... checking out the non factory wiring.
Ohhh .... and the little pwado should meet your requirements pretty well. ;)
Big Rig
You clearly don't know much about Prado's do you.
bmurray2250
Big Rig, I agree with you he doesn't know the Prado. 4wd Action rated the Prado extremely high. Best for touring, offroad ability up to moderate, fuel load and able to carry up to 8 people. That was against the 105 Cruiser and Hilux. May not have the power of a Jeep but driving from Brisbane to Sydney without fueling with heaps to spare and able to carry a good load as well makes it a good 4wd. Horses for courses, Prado is classed as the best mid size 4wd
billolga
A few years ago I was in the Diamantina on our own & found ourselves with MUD everywhere! We joined up with 5 PRADOS mostly standard driven by SURGEONS & ANESTHETISTS together with two other orphans (80 series & F250) we got out of there in Convoy helping each other.
I was VERY IMPRESSED WITH THE PRADOS - You have got yourself a good vehicle Clough Just right for your size Family.
(I know - senility must be setting in - I HAVE A PATROL - NO, I am not buying a PRADO - I will wash my mouth out after.;) )
cloughcarib
Ha Ha Carves. You're the only one out of the 'Jeep crowd' who's ever given me good advice over the years, so I'll have to put these comments down to jealousy;). Yeah, I still dream of owning a Delica one day:rolleyes:, but I'll have to make do with the Pwado for now:):eek:
teza h
Yeh! good one Clough,I think that you made a good decision there with the Prado and I'm sure you will love it. They are a realy good off road tourer,and I'm not just being biased here, they realy are a great vehecle.
Cheers Teza.
carves
Big Rig, I agree with you he doesn't know the Prado ...........
Yeah ... You'se are probably right .... :rolleyes:
heh heh .... will never be jealous of a tojo ..... owned enough of the damned things to know they are just another box on wheels. :D
Doesnt matter what the sticker is - on the bonnet ... Its whether a vehicle meets your requirements thats important ... ;)
Besides .... the widdle pwado will be a good interim vehicle as a lead up to the refined 4wd qualities and abilities of the Delica .....
Enjoy the little station wagon ... and now you can go somewhere without stopping for fuel every twenty minutes .... maybe a run out west ?????
Just dont go and get all toyotafied like some .... as I'd hate to see you lose your ability to enjoy a joke about what your driving ..... ;)
richardlnsw
The 4wd action comparo. last year in the N.T.
5 standard '09 4wd's, Pajero, Patrol, Prado, Jeep Cherokee (i think) and i am pretty sure the other was the Hummer, i may be wrong on that. They put the cars through heaps, each driver changing vehicles at times. The vote ended up Patrol 3 and Prado 2, all drivers saying that there was not much between them, but they thought that the Patrol was just that bit better off road, but not as smooth. The others didn't get a rating.
I just took my Prado through almost everything that Cape York had to offer and did it very well. Friends in cruisers and patrol couldn't believe what i put the car through and how well it handled it.
Just a bit of extra fuel to the fire.
