Barra GU
Hi All,
Just have a bit of a question in regards to the following,
I have currently installed a new diff drop kit with after market upper control arms to my rig today. The vehicle is a 2013 Mitsubishi Triton with adjustable monster rides suspension in it. The car is lifted to 3 inches on the front.
Given this as you know, lifting the front end of an ifs vehicle can open up a can of worms so i am obviously on the up hill climb of trying to overcome potential issues with this current set up.
With the vehicle just lifted to 3 inch using the suspension, the cv angles were pretty bad so decided to fit a diff drop kit and after market upper control arms.
Once fitted i have noticed the the bottom results and have a few questions as to how i can overcome these potential issues.
Diff drop: kit is designed to give your cv's a better angle, after looking at my cvs and compared to my mates at 3 inch yes mine are sitting a lot better so thats a win
Upper control arms: After these were fitted ( one side only) I noticed the front droops 40mm lower than the other side that still had the factory upper control arm. Whilst the vehicle was on the hoist these measurements were taken but i found that on the side that the after market control arm was on it would also cause cv binding because of the excessive droop.
I spoke to a few people whilst there and decided safer option was to take out the after market arm and re install the factory ones which will allow the front end cvs to work within there limiting parameters.
Then spoke to a few other people and they told me that given the fact that the vehicle was up on a hoist and wheels completely maxed out i would never really be in that situation so i am best having the vehicle flat on the ground and lift the front end up (one side at a time) and work out where the opposite wheel wants to bind and limit it somehow whilst still incorporating the new after market arms.
So called them up again and said Dont worry about it leave the aftermarket arms in and apologised for the stuff around.
Now: After doing a bit of research myself there are 2 ways i could really go about this
A: leave the factory arms in and remove bump stops which gives them a little more droop but is limited due to the arms not having as much travel which in theory leaves the cv's within there working parameters
B: Leave the after market arms in and find the limiting point prior to binding and make/fabricate a droop stop which prevents it from allowing the cvs to bind.
The problem i believe i will currently have with out droop stops is : If i was to go wheeling now with the after market gear in, lift a wheel the lifted wheel will droop fully while in 4wd (and front locker on ) and believe due to this may cause something to snap.
Also, Ball joints tie rods look ok and gets alignment done when i pick up tomorrow
A: Am I on the right path in thinking of limiting the upper control arm droop to keep the cvs within the working parameters?
B:What else that i havent mentioned above do you believe i should possibly keeping an eye out for ?
C: Although diff drop kits and upper control arms give us a false expectation that your cvs are going to be ok the upper arms now cause the cvs to go further down so in theory running into same but different dramas
D: What would you do to help perfect this current scenario
Thank you for your time and look forward to your input
