I want more height and less rigidity
hzadbhat
Hey all,
My project is about to get underway this weekend!
I'm the proud daddy of a cute little 1985 4runner but i'd like some advice off you all please.
I'd love a few more inches under my baby and for her not to rattle my teeth out on a highway. Don't even ask what rattles out off road!
i'm going to get real people to install my new suspension but i've not got the foggiest about it. can anyone here recommend what i should get?
i'm going to spend some real money on getting my girl seriously off road, so i'd like to know what is actually good.
If anyone has a budget option that they've actually done, i'd like to hear about it as well.
Thanks all :D
345 chippy
good luk in finding a susspension that dusnt smash ya teeth out in ya truk:D
my every day driver is a 86lux(same as your surf). the susspension is harsh unless u want 2 spend big $$$. ciol conversion(big $$ again), probably would not bother, and just buy a $4000 gq its all ready gt coils. and far better ff road.
(my dirt toy is an 80 but u cant get 1 4 that much)
good luk m8, only my 2bobs worth;)
cheers chippy
hzadbhat
appreciate yur advice chippy, but way way back in 85 at chrissy time i saw the fourby i knew i wanted and have wanted ever since.
It has now been in my driveway for about 6 months.
I'm very aware that i've gotta spend some serious coin on the suspension bits and bobs, but i don't care. This vehicle has been a dream of mine for over a quarter of a century and it's finally happening! YAY!!!
Again, thanks :cool:
dudelux
In short, your car has leaf springs. It will never be as comfy as something with coils.
There are lots of ways you can get them work very well offroad, but they will still never give you the comfiest ride.
You could buy lifted springs and shocks and bolt them in. The Locktup 3inch flex springs are supposed to be really good, soft and flexy.
You could make your own leaf packs by adding/removing leaves from different stock and lifted packs to make a set of springs that works for you and what you want.
You could do whats known as RUF(rears up front), and IFS rears. This needs a few more mods to be done in order for it all to work properly. But Ive seen very good results from this. And I have this setup on my 86 Lux.
I have a mate here on the Central Coast selling his 3inch lifted EFS leaf springs. Front and rear. Then all youll need to get is some shocks to match.
PM me if youre interested.
They do work very well too.
Lots and lots of options for you, but it all comes down to how much you want to spend, and how much you can do yourself/mates.
muc the truck
first of all leaf spring set ups can be comfy like coils just like some coils can be as hard and harsh as hevy duty leaf set ups .
you have leaf so start tearing out a leave at a time until you get the ride you want realizing you can not cary the same load . theers has been many flexy set ups in competton trucks over the years , Its about spring rate and vehicle weight.
I have leaf on the back with 11x6'' airbags to carry load when I want . little bit like having your cake and eating it too. one very good way to engineer a set up that's flexy and able to carry weight is take a leaf out of land rovers book . use low rate springs a and then apply load caring in the center at the diff. They used hydraulics but its cheaper and more redily available to simply bolt up a air bag to the diff center and bolt it to a cross beam on the chassis . engineered approved of course. this way when you have tools on the back you simply pump one bag up to level the load like land rovers hydraulic set up did on the range rovers once had.
Ozbogwam
Longer springs is the answer. Rear springs up front involves new spring mounts and driveshafts usually, moving the axle forward also helps change the balance point and tends to improve the ride as the further away you are from the doffs the more comfortable it is. In the rear go for longer springs as well, from memory the US guys used to run 56" Chevy springs. It all can be done but it can add up to some serious $$$ and fabrication to get it truly dialled in
Just because its leaf not coil doesn't mean you can't have comfort and capability.
Why do you want the extra height?
cloughcarib
Your passion is inspiring. I wish you all the best.
