I think that I need to fix this.
cloughcarib
Had the day of work today sick, and decided to pick up the kids from school. After pulling back into my driveway I noticed that the front drivers side was sitting VERY high. I jumped out to find my drivers wheel folded under the car!!!!!!!
The castle nut had come off the upper ball joint and the steering assembly dropped off:eek:
After further inspection, I found the thread totally stripped and the remainder of the split pin inside the thread so obviously it's sheared at some point and slowly undone. The castle nut was sitting under my car and only 4 of 12 threads were clean so we were dam luck it happened in the driveway not on the road.
Thankfully the only other thing that's damaged is the sway bar linkage.
I've ordered the parts to rebuild both sides and they should be here by Monday.
I wish I had taken a pic of the wheel under the car, but my head was wrapped around fixing the problem.
Then I realised the next problem. My car was blocking Debby's in so it had to be moved. Hence the photo of my solution to move the car:rolleyes:;)
prawns
Mate this wheel falling off thing is starting to become a bad habit? ;) :D
Crikey just think how lucky you were it happened in the driveway anyway mate - somebodys watching over you I think. Reckon I might dive under my car and check a few things after hearing about yours (my front stone tray has a habit of loosening bolts over time)
cloughcarib
This is the third time I've pulled up lucky recently in regards to wheels. Hopefully the problems stop or the luck continues;)
At least I can fix it easily myself.
underdog
I just hope I don't keep following this trends of yours, Clough... first I almost lost a wheel due to loose wheel nuts like yourself, and I drove off site Tues last week with the boot open and my Esky fell out :/ please don't get any more creative with these goofs. Should I check my steering assembly now too?
03hilux
Gees mate, that's a close call (again).
I think its time the Prado got a thorough going over with a fine tooth comb.
Just a quick thought, if you used your vice grips to hold the steering together, what was holding your key together?
cloughcarib
Ya just a copycat;)
As soon as the parts turn up and get replaced she's getting booked in for a checkup.
03hilux
Ya just a copycat;)
Check it all yourself. Just have a good look at every nut and bolt and run a spanner over them. Also check for wear marks around them that shouldn't be there. Don't forget, to check the rear shocks top mount. A lot of DIYers overlook them.
joebog
It must have been flogging for quite a while !!!!! to strip the whole bolt.
I suggest ya remove at least 10 or 12 subwoofers :D
Didnt ya hear it?? or feel it ???
Joe
cloughcarib
Joe
It had unwound to the last four threads then gave up as I entered my drive.
Didn't feel it or hear it as I've got the muddies on at the moment. I've ordered the the parts to replace both sides as I noticed last week that the upper on the other side has started leaking grease.
Toddyh
Very lucky mate. Could have been very dangerous and far more expensive. Studying the service manual and memorising all the required torques on every bolt now?:p
cloughcarib
Missed this comment before, Roger.
Obviously I'm starting to run out of vice-grips in the tool bag, there's still a couple of pairs left:p;)
cloughcarib
The upper ball joints and sway bar links turned up today. I've bought from SuzukiSuper on eBay before and their shipping times and prices are fantastic. Last thing I bought from them were CV boots.
I'll just need to set up a tarp and get stuck in. At least I'll be able to drive to work on monday(ill have to take the work truck back this weekend though).
cloughcarib
Haha. Christmas isn't too far away, so you could always ask Deb and the kids for more.:D
Haha. I think I've swallowed birthday/Christmas presents for a while with repairs/mods to camper/Pwardo over the last few months.
I'm not sure Deb'll be sold on the idea of more tools:confused:
cloughcarib
Well, it took nearly 2 1/2hrs to get the old balljoint out and after two hrs with the wrong tools, I gave up putting the new one in. I'll make a two point puller tomorrow and get it done.
cloughcarib
Bit the bullet and bought a puller from Repco and had it pressed in within half an hour. I had to adapt a 35mm socket to do the job. Will do the other side next weekend;)
