senyasocial
Hello!
I have a 1989 Toyota Landcruiser BJ74 with a 13BT engine
I have a coolant leak but don't know the name of the part
It might help me to get quotes and such if i can use the part name
The component appears to be a two-piece "clam-shell" housing on the front of the engine below the water pump. The main pulley (I think it's usually called the crank pulley) to which all the accessories are connected by belts, attaches to the front of this housing. Then the whole housing bolts onto the front of the engine block. What is this housing called?
The coolant leak is in the gasket between this housing and the engine block.
Thanks in advance!
Thanks in advance!
