How To Get More Flex???
thejetstar
Got 93 4runner with IFS and coil in the rear.....Got a 2 inch lift and want more flex in the suspension.....whats the first step I should take????? Any help would be appreiciated
muc the truck
the only way your going to get more suspension drop in the front is to restore the front back to standard height . then you will have 2 more inches of droop to help permit the front end to retain traction. You have reduced its droop going up and as a consequence you now get air under one front wheel more often than you did before .
For the rear , go for a spring rate more designed to the load you carry.
MatOZ
Removing swaybars will allow more flex.
But i do not recommend it and neither does the law.
Bush Ranger
If a ``93 4runner with IFS and coil in the rear``, it would probably have a beam axle in the rear of the vehicle, it probably would have a sway bar too. The only IFS vehicle I had was a Triton ute with leaf springs in the rear and I found the Triton a bit too limiting for me when I went off road. Try Superior Engineering and or similar sites when searching. Some one else more experienced in IFS than I, would correct my info.
red hilux
thejetstar
I know this is on heaps of other forums but if I put in a rear locker and my front wheel lifts the back wheels should still drive shouldn't they??? Saving for a E LOCKER amongst other things want a auto locker in the front one day got to get free wheeling hubs first
thejetstar
Gonna just get new torsion bars tough dog.....apparently they go up to a 4 inch lift so if I keep mine as 2 or 2.5 and should be able to get max travel out of it.....there only $250.......LOCKERS FOR CHRISTMAS.......maybe:D
red hilux
Get a front locker first. Makes up for lack of front flex.
You should have manual hubs already bring a 4runner. Surfs had auto hubs
red hilux
Winding up the front torsion bars limits down travel. You don't want to wind them up to far. ( also affects cv angle)
