How to get .gpx file from track?
Soaked_As
Choose the one labelled GPX :D
("GPX XML")
I did find it eventually! It's quite a list ...
Would anyone know how to get that downloaded file emailed to an address without using a desktop? Currently it seems I have to attach it to an email to email it to myself to open it on my phone to get it into the GPS program.
prawns
If you have a iphone/ipad/idevice then sending the gpx file via email and then opening the email with your phone is perhaps your only option as far as Im aware? (I stand to be corrected but its how I used to do it also with a iphone)
If you have a android, just copy the GPX file direct to the phone and click on the file from within your phone file manager, or wifi direct, or bluetooth it etc
Soaked_As
Yes exactly but I can't get the email unless I first download the file to my computer which will be tricky when I'm on the road!
darb
use dropbox mate.
i open my GPS files from the dropbox app on my phone, in my case KMZ or KML files which then open in google earth ... or GPX into a different app (can't recall its name but i stopped using GPX coz the app was freezing too much).
The best hting about using dropbox method is you set it as a favourite, and it caches it ... so you can still relaunch it from dropbox even if offline.
bbbflash
Hi guys, sorry if I am hijacking this thread. Happy for it to be moved. I use memory maps to open the GPX formatted tracks. When I download and import them into memory maps I get the route, but it also puts 300+ flags along the route. I then have to go through and delete them individually. My questions are, is there a way to import them without the flag and if there is a way to do mass deletes in memory maps. The photo says it all. Thanks.
prawns
Those look like "waypoints"
Delete them and perhaps you lose the ability to route properly? (you would have to follow the track manually by watching the screen which isnt such a issue for low speed offroad stuff anyway I guess)
Perhaps a easier way is just to turn off "display waypoints" or similar from within the app, or change the wapoint icon to something less intrusive (I have no idea if either is a option in memory maps as I dont use it but gives you a idea where to look perhaps)
Keep in mind - a gps file is just a file full of "waypoints" (gps co-ordinates) in its most basic form. In some apps deleting the waypoints will also delete that part of the track automatically (depends on the app - alot are happy to leave the "track" behind even though you deleted the "waypoints" which created the "track" itself - its all over my head at that stage lols)
Just keep in mind - the offroad gps apps use waypoints to "guide you", so if you actually delete the waypoints then realise you will lose the ability for the gps app to "guide you" to the next waypoint and along the track as you drive it (it will instead "guide you as the crow flies" directly to the end of the track which is generally unhelpful - better to hide the waypoints from view instead if you can - just to keep functionality)
Prawns is on the money. You can just show tracks and not way points.
If you have Memory Map for the PC which is free, you can put the track in one folder and the way points in the other folder then chose not to display the waypoint folder or delete it in one click.
Read some of the user experiences on this, and other forums and I think the answer will become very obvious.
Phoenix4x4
can we still download GPX files? this might sound stupid, i defiantly feel stupid but i cant seem to find the option to download them any more? i just got a Hema HX-1 and wanna download some GPX tracks to it, any help?
Thank you =)
