How to fit recovery hooks to chassis
Adam n Ros
Hi everyone,
I'm new to the forum and 4wding. Had some awesome advice given to me on here already.
I drive a 2002 Suzuki Grand Vitara. I'm probably not going to hang onto it long term so don't want to spend heaps, just have a bit of fun with it prior to getting a bigger 4wd for the growing family. The only modification on it is a TJM alloy bullbar.
I need to fit some recovery hooks. In a previous post the Ridge Ryder 4500kg tow hook kits at super cheap or similar were recommended to me. Now I need to work out where to install them. Is this a job I can do myself? I'm fairly handy, but if it is a pro only job I'll pay to get it done...?
I can't work out how to post photos, but at the front of the vehicle, most of the places on the chassis I could bolt the hooks onto would then cause the strap to foul on the bullbar..?
On the rear I have a towbar (not a hayman reece style). Can the rear hook be attached to this in some manner?
I'm not doing anything where I'm going to be buried deep in the mud, but do want to get out on the beach etc so need to put something on, as I'm aware the factory tie down points are in no way adequate.
I've got photo's, if they are any help to anyone on here to see where they could go - just can't get them to load onto the message...
Thanks for any help that can be offered!
Cheers,
Adam
Adam, I fitted my hook to the same bolt holes as one of my tie down points.
See pic.
Thought I have a pic of my original tie down, but no, will just see if I can find one online . . .
Ok, second pic is a fairly typical tie down, and the after market hook uses these same holes.
Take a good look underneath for std tie downs, maybe they've been removed to fit the bar.
The bar has no recovery points ? Some do.
If your bar is in the way of the hook, you might have to mount somewhere else that is structural.
Rear towbar. Hmm, wanna be careful, unless you are being snatched out backwards, you will be doing the snatching from that one.
Little more than tow recovery type stresses, should be ok to use a shackle with pin through tongue hole (ball removed), but you must be sure the whole unit is bolted on well, tongue is fixed part of towbar (welded) or very good HT bolts.
Pretty sure plain tongue type towbars are not rated as high as Haman Reece square hitch type towbars, pretty sure HR type are pushed as a heavy duty option.
Ok, you're in a Vitara, nice and light, not much needed to pull it out of moderate sand bogging, but you might have to assist something bigger / heavier one day.
Adam n Ros
Hey Les,
In the first photo, is there a nut on the other side or have you drilled and then tapped a thread into the chassis rail?
It looks as if your hook is set higher than the bottom of your bullbar relative to the ground level? This is what I'm wondering about, as it looks as if a snatch strap or winch cable would catch on the bar?
I can't seem to upload photos of where I'm looking at attaching mine - just comes up with a script prompt...
Cheers,
Adam
Aaron Schubert
Make sure you use washers, and minimum M12 and 8.8 grade. For rear recoveries, just get a hitch receiver for about $45 - the easiest way.
Aaron
Hey Les,
Cheers,
Adam
Hey Adam, sorry mate just back from weekend away.
My hook is level with the lower bar, just like the other side OEM hook.
It works fine, no damage as yet, but I am not worried about that as eventually plan to replace F & R bars with custom pipe type bars.
Those 2 bolts in the first pic (on the hook) were where the 2nd pic type of toe down was located.
There is a welded nut in there.
Most tie down bolt holes SEEM to be the size of the hook holes, so just rebolt on (albeit with new high tensile bolts.
If your's doesn't have these, then you might be better to get some sort of standard recovery point from a 'normal' 4WD retailer like ARB, TJM, Opp Lock etc.
They are more like plates that bolt onto OEM holes for each make / model of cars, BUT they are not made for all vehicles, so check around with a few phone calls or emails.
If you have to drill and mount a hook type recovery point, chassis are hollow, so you'd have to pick a point that allows you to get a spacer sleeve inside to prevent the chassis squishing in as you do up the HT bolt / nut / washer etc.
While you can get captive nuts etc for some applications of bolting things on, this is not a good idea for recovery points.
They would be prone to ripping out.
Even the tie down points probably only have a decent nut welded inside, but a lot stronger than a captive nut type of scenario.
Adam n Ros
Thanks guys. I had a look underneath and the factory tie downs are welded not bolted, so I'd need to drill and insert a sleeve as per advice above...
For safety's sake I might get a couple of quotes to get it done for me at a 4wd store or at least get them to supply me all the correct sized bits.
I was hoping it would be easier, but no point doing a huckory job where safety is concerned!
Cheers,
Adam
80lover96gxl
Maybe do a google search on your vehicle to see if those points on the front are in fact rated points, as there welded on there is a possibility they are rated already.
Still use both factory points on both my cruisers with never an issue and they've been thru some big recoveries.
Maybe a little research on yours might save you the job of changing unnecessarily, especially with a light vehicle like yours.
Yes, a good Google or phone a Suzi dealer might be worth a shot.
There're probably a Suzi forum or two out there where good info can be sourced.
My left hand side hook has been used many a time for recoveries, along with the new bolted on after market hook . . . it is bolted on as per the right hand pics sent the other day, found a pic (below).
Maybe post a pic of your welded points for some consideration by Earthers ?
Try and show the full welding, idea of size, etc.
It's usually easy to see if something is up to a light task by the design of the point, thickness of metal, etc. Eg. the tie downs are normally just 4mm or so thick metal, which is potentially too weak.
Also, as mentioned in one of my posts above, you might find a bolt on plate type of recovery point/s is made for your vehicle, but you might have to phone around a few of the 4WD retailers like ARB, TJM, Opp Lock. etc.
