How much oil
RainbowCruiser
Some of you may remember my recent suspicions about my head being gone well it was. It wasn't cracked but it was bent.
So I've just ordered a new head with all the gaskets and bolts.
My brother in law is going to help me fit it as he's a qualified mechanic (my family think I'm crazy for being female and wanting to learn this stuff)
So I'm guessing since all my oil and water mixed together I'll need to do a few flush outs?
How much oil will I need?
I've got a couple of oil filters because I realise I'll have to change that often for a while.
Sent from my SM-N9005 using Tapatalk
dno67
Engine oil.
10.2 ltr with filters, 9.0ltr without filters.
Always a good idea to drive a short distance under normal conditions then drop the oil and change the filters after repairs like a head repair/replacement.
muc the truck
while the head is off , nock out any accessible welsh plugs and degrease water passages and finish off by blowing compressed air and brake clean in them , this will get rid of mud too from metal corrosion over the years and cool the engine better . this way you will have a clean block . new welsh plugs required. The radiator needs to be filled with a few ltrs of petrol with holes blocked . hose clamp and some old rubber tube works . then empty and and add metho and repeat . rinse with water . Its a good trick to add some degreaser to the cooling system at the dilution rate recommended to degrease and run it for 10 minutes only after its warmed up WITH THE RADIATOR CAP OF then flush the cooling system with clean water before you add coolant and drive it . If the radiator is still blocked after this you need to take it to a radiator shop to remove header tanks and chemical clean or maybe cheaper to replace radiator depending its condition
