Home Network Setup
MawsonSnow
Hey,
Im after some advice on getting my house hooked up to my router in another room,
Ive looked into wiring up the rest of the house with ethernet cables etc but the way the house was built its going to be a huge task...
Ive been looking at those networking kits that use the electrical cables from the homes 240v to plug ethernet cables to and from?? Has anyone used these?
And the wifi on my router is only good for 2 rooms and ive tried the repeaters you can buy but i still cant get decent signal up stairs :(
Any advice would be appreciated
eman
I use one of those 240v network kits (TP Link) at home and it's working a treat. Has been pretty reliable only had to power cycle it twice in 12 months.
Have used the older Netcomm ones before but found them a little less reliable
MawsonSnow
Thanks for the reply mate, just have to make sure the power points im using are on the same circuit breaker or they wont apparently work?? Thats what the tech support told me anyway
Being a network cable guy that does it for a living I will say they are no good:oops::rolleyes:
Seriously I have never used them so can't really comment but have heard from guys that do a lot of gamming that they buffer a lot more than a good Ethernet install and I don't think you will get full speed if connected to NBN, for that you will need Cat6 UTP.
For the average user on slow old ADSL it will probably do the job, but having said that if you have to use it on the same power circuit that makes it hard as the average home only has 2 or 3 circuits and up stairs will probably be different to down stairs.
If you where in Melbourne I would offer my services but a little far for a look and a bit of advice
MawsonSnow
Hey @discomatt what is the normal going rate to install cat6 cable throughout homes these days? I got quoted $1600 for 5 rooms...
Seems a bit expensive to me but im not a expert in this field lol
Hard to say without seeing the house, with under floor or ceiling access I would allow a full day at roughly $600 and about $300 in materials. If you wanted it all enclosed in a cabinet and terminated to a patch panel it would add another $400.
If they just terminate to outlets on wall plates at each end its a bit pricey. If you do get it done make sure they test and label each point
MawsonSnow
Yeah its a double storey house with very tight underfloor access etc, and the cable was going to be terminated at the outlets, so i guess the quote isn't far off the mark,
Ill get a photo of the quote in the next few days and let you have a look, as i said i have no clue about this sort of work to make sure he isnt taking me for a ride
red99td5
I tried the Ethernet power adaptors, killed 2 sets in under a year.
Why don't you run the cable yourself and do the terminations as well, it's not hard to do. You can Google terminating to a rj45 jack.
Discomatt, forgive my ignorance but isn't the fastest nbn service available 100mbit? Why would you need the extra expense of cat 6utp when cat 5e is good for gigabit?
Cat5 e is good for gigabit but limited to a shorter distance than cat 6 and in the first lot of specks that came out for NBN Cat 6 was required to guarantee full advantage and speed, that could have changed though. But really if doing a new install put in cat 6 for an extra 20cents / m. and an extra $5.00 for an outlet why use old speck cable, I don't even stock cat5e anymore and only install cat6.
Most computers and routers are fine with 5e but what about 2 years down the track and if moving big files around in a business then I wouldn't even consider cat5 these days, do it once and do it right to the best speck of the day, although there is now higher than cat6 but that is just not worth the extra expence
