from the windscreen back the 2010 Thailand shape is the same as the usa model.
the font has different control arms and front suspension . the usa do not get the diesel and we do not get the grunt v8. nor do we get the awesome interior , full leather , dvd head rests etc.
because of the different engines in usa the transmission is also different.
ii have imported the stainless steel body molding to protect it from the fools in shopping centers and its worked .
I have spent hours comparing the skyjacker lift kits from usa and with measurements they provided there is no way there usa kit fits ours in the front . nor would it now be legal anyway. I can get similar from Thailand but still never be legal so not bothering .
Since I run empty most of the time I removed spring leaves to give a bit of comfort
I made my own airbag mounts and used re-7 slam bags with internal bump stops because there are no kits on the market that use bump stops with the identical clearance as factory , also run a compressor with remote control to monitor the pressures in each bag and it automatically keeps pressures equal which is good for rock hoping and it deflates and inflates as required. its a little slow to inflate but as son as the original compressor dies it will be replaced with a vilair 450c-ig
AIR LIFT 72000 Wireless air leveling compressor reviews | Check latest prices now - YouTube
its a good Ute , reliable . strong chassis. I bought the base model and added cruise and automatic tranny as the carpet in new cars is crap . its not even carpet. I am sure its been placed in there to devalue your car. transmissions both auto and manual are robust , still have the dana style diffs and size. drive line as a whole is stronger than most other Utes in its class. The chassis is 3mm at its thinnest point like land cruiser.
15'' rims still fit so the improve off road and offer a slightly cheaper tyre with deeper tread . more air between the road and rim. this has made it the most comfortable Ute I have been in over the last few years.
The door seals are good for dust . the standard mp3 player skips like a kangaroo.
The auto gives you the impression its set up for load as it changes just like the Alison transmission in the bushmaster. its not car like at all and even though its just a moded version of what's in the petrol jackaroo its so very different . has lock up tc in low range and also a button to start off in 3rd gear in mud and ice. When this is used it climbs out of almost anything as the wheels barley turn.(all the slip is in the tc) Economy is good . I can get 15/100 towing ford sedan on a car trailer at gps speed of 100. Speedo is out by 5% on standard tyres so reading 100 your pissing people off and doing 95. adding the bigger tyres 31/10r/15s fixed it but I still use gps anyway on long trips to warn me of speed cameras.
I have done a water crossing above the sills . was very surprised no water came in. I don't push water. it breaks traction and water was swift, I drive slow enough so the water is level from front to back or as close to it.
